WINS Proxy and/or 0xc0040014 ?
WINS Proxy and/or 0xc0040014 ? - 10.Sep.2004 5:49:00 PM
grinn253
Hello again!
Appears that our ISA 2k4 setup may almost be close to completion. Here is the setup:
External NIC = 128.208.125.85 /26 Internal NIC = 128.208.125.19 /26 Clients NIC = 192.168.125.100 /24
Every NIC for ISA is on its own network, we have put the client workstations on the 'Client network' and the servers on the 'internal network' So far traffic/policy is working pleasureful between the internal/external/client networks.
Except that when client workstations broadcast what i believe is a name query to 192.168.125.255, ISA denies the conection (port 138) with a result code of: quote: 0xc0040014 FWX_EFWE_SPOOFING_PACKET_DROPPED
What then happens is when viewing a file such as a .doc that is stored on a network file server, the connection is lost (ISA produces the 0xc0040014 code) and Word, asks the user to reconnect to the server or exit.
So, I created a Lmhosts file for workstations that #PRE and #DOM the fileservers and also has \0x1b \0x1d entries for a DC.
The workstations still wanted to broadcast (bypassing lmhosts file?) but nbtstat -c shows that indeed the lmhosts file is being parsed correctly (determined by life -1)
Finally, would someone be kind to let me know how isa can allow the 192.168.125.255 broadcast traffic? I'm going to regedit ISA to enable it as a WINS Proxy to see if that helps, in the mean time, thank you for your time!
Edgardo
p.s. a good article on WINS Proxy: WINS Proxy [ September 10, 2004, 05:51 PM: Message edited by: grinn253 ]
RE: WINS Proxy and/or 0xc0040014 ? - 14.Sep.2004 7:55:00 PM
penrose.l@2college.nl
Hey Grinn,
Let me guess you have a NAT relationship ? check this out. I spent 4 weeks to find where this error originates.
KB 301673 û ôYou Cannot Make More Than One Client Connection Over a NAT Deviceö describes the issue. See http://support.microsoft.com/default.aspx?scid=kb;en-us;301673 for more details
This should definately be a sticky ( tom ? ) because it's a big problem with ISA.
Lex P.
RE: WINS Proxy and/or 0xc0040014 ? - 15.Sep.2004 4:29:00 AM
Hi Lex,
Why not just disable NetBIOS on the clients and use DNS? Or how about just using a WINS server to get rid of the broadcasts, and finally, disable the dreaded browser service on all hosts.
HTH, Tom
RE: WINS Proxy and/or 0xc0040014 ? - 15.Sep.2004 4:31:00 AM
Lex P.
Hi Lex,
All Internal networks should be routed, so that NAT issue isn't an issue. Are you NATing between internal networks? If so, why? There are a lot of disadvatages and few if any advantages.
HTH, Tom
