WSUS and ISA 2004
All Forums >> [ISA Server 2004 General ] >> General >> WSUS and ISA 2004 Page: [1]
WSUS and ISA 2004 - 28.Oct.2005 8:57:00 AM
dasmail2000
Hello all -
One of my clients has an ISA Server 2004 in Single Network Adapter configuration (it is basically just a proxy server...no, I am not thrilled with the config but let' s not get in to that whole discussion "[Wink]" )
It is configured to use a WSUS server for updates but with the ISA services started it always fails. Here is the log-
2005-10-27 14:23:11 1104 d2c AU Triggering AU detection through DetectNow API
2005-10-27 14:23:11 1104 c54 AU #############
2005-10-27 14:23:11 1104 c54 AU ## START ## AU: Search for updates
2005-10-27 14:23:11 1104 c54 AU <<## SUBMITTED ## AU: Search for updates [CallId = {8F9080E8-BA4B-4C3C-B71E-DE56226272C7}]
2005-10-27 14:23:11 1104 530 Agent *************
2005-10-27 14:23:11 1104 530 Agent ** START ** Agent: Finding updates [CallerId = AutomaticUpdates]
2005-10-27 14:23:11 1104 530 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80190193
2005-10-27 14:23:11 1104 530 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80190193
2005-10-27 14:23:11 1104 530 Misc WARNING: DownloadFileInternal failed for http://dvdsrv1/selfupdate/wuident.cab: error 0x80190193
2005-10-27 14:23:11 1104 530 Setup FATAL: IsUpdateRequired failed with error 0x80244018
2005-10-27 14:23:11 1104 530 Setup WARNING: SelfUpdate: Default Service: IsUpdateRequired failed: 0x80244018
2005-10-27 14:23:11 1104 530 Setup WARNING: SelfUpdate: Default Service: IsUpdateRequired failed, error = 0x80244018
2005-10-27 14:23:11 1104 530 Agent * WARNING: Skipping scan, self-update check returned 0x80244018
2005-10-27 14:23:11 1104 530 Agent * WARNING: Exit code = 0x80244018
2005-10-27 14:23:11 1104 530 Agent ** END ** Agent: Finding updates [CallerId = AutomaticUpdates]
2005-10-27 14:23:11 1104 530 Agent WARNING: WU client failed Searching for update with error 0x80244018
2005-10-27 14:23:11 1104 530 AU >>## RESUMED ## AU: Search for updates [CallId = {8F9080E8-BA4B-4C3C-B71E-DE56226272C7}]
2005-10-27 14:23:11 1104 530 AU # WARNING: Search callback failed, result = 0x80244018
2005-10-27 14:23:11 1104 530 AU #########
2005-10-27 14:23:11 1104 530 AU ## END ## AU: Search for updates [CallId = {8F9080E8-BA4B-4C3C-B71E-DE56226272C7}]
2005-10-27 14:23:11 1104 530 AU #############
2005-10-27 14:23:11 1104 530 AU AU setting next detection timeout to 2005-10-27 19:17:44
Yet, when we shut the ISA services down, it works fine (as seen here)-
2005-10-27 14:23:16 1104 47c Report REPORT EVENT: {A9922AE3-4F31-43CF-96A3-A0AC2EF1A64A} 2005-10-27 14:23:11-0400 1 148 101 {D67661EB-2423-451D-BF5D-13199E37DF28} 0 80244018 SelfUpdate Failure Software Synchronization Error: Agent failed detecting with reason: 0x80244018
2005-10-27 14:24:12 1104 2e4 AU Triggering AU detection through DetectNow API
2005-10-27 14:24:12 1104 c54 AU #############
2005-10-27 14:24:12 1104 c54 AU ## START ## AU: Search for updates
2005-10-27 14:24:12 1104 c54 AU <<## SUBMITTED ## AU: Search for updates [CallId = {EDF0CE2F-2FD1-499B-B77D-A0F555AD75B6}]
2005-10-27 14:24:12 1104 47c Agent *************
2005-10-27 14:24:12 1104 47c Agent ** START ** Agent: Finding updates [CallerId = AutomaticUpdates]
2005-10-27 14:24:12 1104 47c Setup *********** Setup: Checking whether self-update is required ***********
2005-10-27 14:24:12 1104 47c Setup * Inf file: C:\WINDOWS\SoftwareDistribution\SelfUpdate\Default\wusetup.inf
2005-10-27 14:24:12 1104 47c Setup Update NOT required for C:\WINDOWS\system32\cdm.dll: target version = 5.8.0.2469, required version = 5.8.0.2469
2005-10-27 14:24:12 1104 47c Setup Update NOT required for C:\WINDOWS\system32\iuengine.dll: target version = 5.8.0.2469, required version = 5.8.0.2469
2005-10-27 14:24:12 1104 47c Setup Update NOT required for C:\WINDOWS\system32\wuapi.dll: target version = 5.8.0.2469, required version = 5.8.0.2469
2005-10-27 14:24:12 1104 47c Setup Update NOT required for C:\WINDOWS\system32\wuauclt.exe: target version = 5.8.0.2469, required version = 5.8.0.2469
2005-10-27 14:24:12 1104 47c Setup Update NOT required for C:\WINDOWS\system32\wuauclt1.exe: target version = 5.8.0.2469, required version = 5.8.0.2469
2005-10-27 14:24:12 1104 47c Setup Update NOT required for C:\WINDOWS\system32\wuaucpl.cpl: target version = 5.8.0.2469, required version = 5.8.0.2469
2005-10-27 14:24:12 1104 47c Setup Update NOT required for C:\WINDOWS\system32\wuaueng.dll: target version = 5.8.0.2469, required version = 5.8.0.2469
2005-10-27 14:24:12 1104 47c Setup Update NOT required for C:\WINDOWS\system32\wuaueng1.dll: target version = 5.8.0.2469, required version = 5.8.0.2469
2005-10-27 14:24:12 1104 47c Setup Update NOT required for C:\WINDOWS\system32\wucltui.dll: target version = 5.8.0.2469, required version = 5.8.0.2469
2005-10-27 14:24:12 1104 47c Setup Update NOT required for C:\WINDOWS\system32\wups.dll: target version = 5.8.0.2469, required version = 5.8.0.2469
2005-10-27 14:24:12 1104 47c Setup Update NOT required for C:\WINDOWS\system32\wups2.dll: target version = 5.8.0.2469, required version = 5.8.0.2469
2005-10-27 14:24:12 1104 47c Setup Update NOT required for C:\WINDOWS\system32\wuweb.dll: target version = 5.8.0.2469, required version = 5.8.0.2469
2005-10-27 14:24:12 1104 47c Setup * IsUpdateRequired = No
2005-10-27 14:24:13 1104 47c PT +++++++++++ PT: Synchronizing server updates +++++++++++
2005-10-27 14:24:13 1104 47c PT + ServiceId = {3DA21691-E39D-4DA6-8A4B-B43877BCB1B7}, Server URL = http://dvdsrv1/ClientWebService/client.asmx
2005-10-27 14:24:13 1104 47c PT +++++++++++ PT: Synchronizing extended update info +++++++++++
2005-10-27 14:24:14 1104 47c Agent * Found 0 updates and 8 categories in search
2005-10-27 14:24:14 1104 47c Agent *********
2005-10-27 14:24:14 1104 47c Agent ** END ** Agent: Finding updates [CallerId = AutomaticUpdates]
2005-10-27 14:24:14 1104 47c Agent *************
Now, we have configured the ISA server to use the WSUS server as described here - http://thelazyadmin.com/index.php?/archives/53-Allowing-ISA-2004-to-Use-SUSWUSWSUS.html
For troubleshooting, I even allowed all protocols to/from all networks (including local host) and tried a wsusclnt /detectnow and it still failed. Yet I immediately stop ISA services, try another wsusclnt /detectnow and all is fine.
So, I do not think it is not a firewall policy issue, so what could it be?
Any thoughts would be appreciated.
RE: WSUS and ISA 2004 - 30.Oct.2005 8:20:00 PM
nicolasb
Hi
Have you verified that you are running the
latest WU Agent?
http://go.microsoft.com/fwlink/?LinkId=43264
(in reply to dasmail2000)
RE: WSUS and ISA 2004 - 30.Oct.2005 8:25:00 PM
nicolasb
try typing proxycfg -d
RE: WSUS and ISA 2004 - 2.Nov.2005 8:48:00 AM
dasmail2000
The latest clietn is on there and the proxy is set to direct.
Any other ideas?
RE: WSUS and ISA 2004 - 2.Nov.2005 9:25:00 AM
LLigetfa
In your allow rule did you allow anonymous access?
RE: WSUS and ISA 2004 - 2.Nov.2005 9:30:00 AM
dasmail2000
Yup - even allowed everyone to go everywhere in my testing....no joy :/
RE: WSUS and ISA 2004 - 7.Nov.2005 11:18:00 AM
bbevan
as nicolas_b said, but use proxycfg via command prompt to set the proxy to your isa server, (local address/port) worked for me
