WebDav - Problem with one filetype
All Forums >> [ISA 2006 Publishing] >> Web Publishing >> WebDav - Problem with one filetype Page: [1]
WebDav - Problem with one filetype - 30.Nov.2009 7:47:13 AM
mturner
Hi All
Ive been pulling my hair out over this one.
We have an IIS6 server sat behind an ISA2006 box. an external client connects to the webdav folder (authenticated) and can create, delete etc plenty of files.
However, one filetype -.cfm will not copy, you get the "an error occurred copying some or all of the selected files" error.
i have ran a log on ISA to see the difference (below) i copied a .htm file (marc2) which worked fine, and then tried copying a .cfm file (marc) which didnt work.
Can anyone throw any ideas on why this isnt working?
thanks
Marc
HTM File
Original Client IP Client Agent Authenticated Client Service Referring Server Destination Host Name Transport HTTP Method MIME Type Object Source Source Proxy Destination Proxy Bidirectional Client Host Name Filter Information Network Interface Raw IP Header Raw Payload GMT Log Time Source Port Processing Time Bytes Sent Bytes Received Cache Information Error Information Authentication Server Log Time Client IP Destination IP Destination Port Protocol Action Rule Result Code HTTP Status Code Client Username Source Network Destination Network URL Server Name Log Record Type
0.0.0.0 Microsoft Data Access Internet Publishing Provider DAV 1.1 Yes Reverse Proxy www.website.com TCP HEAD Internet - - - Req ID: 43672fc3; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 11/30/2009 12:33:57 PM 0 1 292 332 0x44000000 0x800 11/30/2009 12:33:57 PM x.x.x.x 172.29.49.3 80 http Allowed Connection RuleName 401 Unauthorized anonymous Internal http://www.website.com/webdav/marc2.htm ISA Web Proxy Filter
x.x.x.x - TCP - - - 11/30/2009 12:33:57 PM 1226 0 0 0 0x0 0x0 - 11/30/2009 12:33:57 PM x.x.x.x 172.29.49.10 80 HTTP Initiated Connection 0x0 ERROR_SUCCESS Internal Local Host - ISA Firewall
0.0.0.0 Microsoft Data Access Internet Publishing Provider DAV 1.1 Yes Reverse Proxy www.website.com TCP HEAD Internet - - - Req ID: 43672fd2; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 11/30/2009 12:33:57 PM 0 1 577 415 0x44000008 0x900 11/30/2009 12:33:57 PM x.x.x.x 172.29.49.3 80 http Allowed Connection RuleName 401 Unauthorized anonymous Internal http://www.website.com/webdav/marc2.htm ISA Web Proxy Filter
0.0.0.0 Microsoft Data Access Internet Publishing Provider DAV 1.1 Yes Reverse Proxy www.website.com TCP HEAD Internet - - - Req ID: 43672fd6; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 11/30/2009 12:33:57 PM 0 1 3311 607 0x40000008 0x980 11/30/2009 12:33:57 PM x.x.x.x 172.29.49.3 80 http Allowed Connection RuleName 404 Not Found anonymous Internal http://www.website.com/webdav/marc2.htm ISA Web Proxy Filter
0.0.0.0 Microsoft Data Access Internet Publishing Provider DAV 1.1 Yes Reverse Proxy www.website.com TCP PUT Internet - - - Req ID: 43672fe8; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 11/30/2009 12:33:57 PM 0 1 1948 331 0x44000000 0xc00 11/30/2009 12:33:57 PM x.x.x.x 172.29.49.3 80 http Allowed Connection RuleName 401 Unauthorized anonymous Internal http://www.website.com/webdav/marc2.htm ISA Web Proxy Filter
0.0.0.0 Microsoft Data Access Internet Publishing Provider DAV 1.1 Yes Reverse Proxy www.website.com TCP PUT Internet - - - Req ID: 43672fed; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 11/30/2009 12:33:57 PM 0 1 2116 414 0x44000008 0xd80 11/30/2009 12:33:57 PM x.x.x.x 172.29.49.3 80 http Allowed Connection RuleName 401 Unauthorized anonymous Internal http://www.website.com/webdav/marc2.htm ISA Web Proxy Filter
0.0.0.0 Microsoft Data Access Internet Publishing Provider DAV 1.1 Yes Reverse Proxy www.website.com TCP PUT Internet - - - Req ID: 43672ff2; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 11/30/2009 12:33:57 PM 0 1 321 606 0x40000008 0xd80 11/30/2009 12:33:57 PM x.x.x.x 172.29.49.3 80 http Allowed Connection RuleName 201 Created. anonymous Internal http://www.website.com/webdav/marc2.htm ISA Web Proxy Filter
0.0.0.0 Microsoft Data Access Internet Publishing Provider DAV 1.1 Yes Reverse Proxy www.website.com TCP HEAD Internet - - - Req ID: 43672ff3; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 11/30/2009 12:33:57 PM 0 1 271 332 0x40800000 0x980 11/30/2009 12:33:57 PM x.x.x.x 172.29.49.3 80 http Allowed Connection RuleName 200 OK. anonymous Internal http://www.website.com/webdav/marc2.htm ISA Web Proxy Filter
x.x.x.x - TCP - - - 11/30/2009 12:33:59 PM 1226 2000 540 460 0x0 0x0 - 11/30/2009 12:33:59 PM x.x.x.x 172.29.49.10 80 HTTP Closed Connection 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN Internal Local Host - ISA Firewall
x.x.x.x - TCP - - - 11/30/2009 12:33:59 PM 1227 0 0 0 0x0 0x0 - 11/30/2009 12:33:59 PM x.x.x.x 172.29.49.10 80 HTTP Initiated Connection 0x0 ERROR_SUCCESS Internal Local Host - ISA Firewall
x.x.x.x - TCP - - - 11/30/2009 12:33:59 PM 1228 0 0 0 0x0 0x0 - 11/30/2009 12:33:59 PM x.x.x.x 172.29.49.10 80 HTTP Initiated Connection 0x0 ERROR_SUCCESS Internal Local Host - ISA Firewall
CFM File
____________
0.0.0.0 Microsoft Data Access Internet Publishing Provider DAV 1.1 Yes Reverse Proxy www.website.com TCP HEAD Internet - - - Req ID: 4367199b; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 11/30/2009 12:33:10 PM 0 1 292 331 0x44000000 0x900 11/30/2009 12:33:10 PM x.x.x.x 172.29.49.3 80 http Allowed Connection RuleNme 401 Unauthorized anonymous Internal http://www.website.com/webdav/marc.cfm ISA Web Proxy Filter
0.0.0.0 Microsoft Data Access Internet Publishing Provider DAV 1.1 Yes Reverse Proxy www.website.com TCP HEAD Internet - - - Req ID: 436719a6; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 11/30/2009 12:33:10 PM 0 1 577 414 0x44000008 0x900 11/30/2009 12:33:10 PM x.x.x.x 172.29.49.3 80 http Allowed Connection RuleNme 401 Unauthorized anonymous Internal http://www.website.com/webdav/marc.cfm ISA Web Proxy Filter
0.0.0.0 Microsoft Data Access Internet Publishing Provider DAV 1.1 Yes Reverse Proxy www.website.com TCP HEAD Internet - - - Req ID: 436719aa; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 11/30/2009 12:33:10 PM 0 31 172 606 0x40000008 0x980 11/30/2009 12:33:10 PM x.x.x.x 172.29.49.3 80 http Allowed Connection RuleNme 404 Not Found anonymous Internal http://www.website.com/webdav/marc.cfm ISA Web Proxy Filter
0.0.0.0 Microsoft Data Access Internet Publishing Provider DAV 1.1 Yes Reverse Proxy www.website.com TCP PUT Internet - - - Req ID: 436719ba; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 11/30/2009 12:33:10 PM 0 1 1948 330 0x44000000 0xc00 11/30/2009 12:33:10 PM x.x.x.x 172.29.49.3 80 http Allowed Connection RuleNme 401 Unauthorized anonymous Internal http://www.website.com/webdav/marc.cfm ISA Web Proxy Filter
0.0.0.0 Microsoft Data Access Internet Publishing Provider DAV 1.1 Yes Reverse Proxy www.website.com TCP PUT Internet - - - Req ID: 436719bd; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 11/30/2009 12:33:10 PM 0 1 2116 413 0x44000008 0xd80 11/30/2009 12:33:10 PM x.x.x.x 172.29.49.3 80 http Allowed Connection RuleNme 401 Unauthorized anonymous Internal http://www.website.com/webdav/marc.cfm ISA Web Proxy Filter
0.0.0.0 Microsoft Data Access Internet Publishing Provider Cache Manager Yes Reverse Proxy www.website.com TCP OPTIONS Internet - - - Req ID: 436719d8; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 11/30/2009 12:33:10 PM 0 1 1948 289 0x44000000 0xc00 11/30/2009 12:33:10 PM x.x.x.x 172.29.49.3 80 http Allowed Connection RuleNme 401 Unauthorized anonymous Internal http://www.website.com/webdav/marc.cfm ISA Web Proxy Filter
0.0.0.0 Microsoft Data Access Internet Publishing Provider Cache Manager Yes Reverse Proxy www.website.com TCP OPTIONS Internet - - - Req ID: 436719e2; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 11/30/2009 12:33:10 PM 0 1 2116 372 0x44000008 0xd80 11/30/2009 12:33:10 PM x.x.x.x 172.29.49.3 80 http Allowed Connection RuleNme 401 Unauthorized anonymous Internal http://www.website.com/webdav/marc.cfm ISA Web Proxy Filter
0.0.0.0 Microsoft Data Access Internet Publishing Provider DAV 1.1 Yes Reverse Proxy www.website.com TCP PUT Internet - - - Req ID: 436719f3; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 11/30/2009 12:33:10 PM 0 1 1948 330 0x44000000 0xc00 11/30/2009 12:33:10 PM x.x.x.x 172.29.49.3 80 http Allowed Connection RuleNme 401 Unauthorized anonymous Internal http://www.website.com/webdav/marc.cfm ISA Web Proxy Filter
0.0.0.0 Microsoft Data Access Internet Publishing Provider DAV 1.1 Yes Reverse Proxy www.website.com TCP PUT Internet - - - Req ID: 436719f6; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 11/30/2009 12:33:10 PM 0 1 2116 413 0x44000008 0xd80 11/30/2009 12:33:10 PM x.x.x.x 172.29.49.3 80 http Allowed Connection RuleNme 401 Unauthorized anonymous Internal http://www.website.com/webdav/marc.cfm ISA Web Proxy Filter
x.x.x.x - TCP - - - 11/30/2009 12:33:11 PM 1221 0 0 0 0x0 0x0 - 11/30/2009 12:33:11 PM x.x.x.x 172.29.49.10 80 HTTP Initiated Connection 0x0 ERROR_SUCCESS Internal Local Host - ISA Firewall
x.x.x.x - TCP - - - 11/30/2009 12:33:11 PM 1222 0 0 0 0x0 0x0 - 11/30/2009 12:33:11 PM x.x.x.x 172.29.49.10 80 HTTP Initiated Connection 0x0 ERROR_SUCCESS Internal Local Host - ISA Firewall
x.x.x.x - TCP - - - 11/30/2009 12:33:11 PM 1221 0 539 460 0x0 0x0 - 11/30/2009 12:33:11 PM x.x.x.x 172.29.49.10 80 HTTP Closed Connection 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN Internal Local Host - ISA Firewall
x.x.x.x - TCP - - - 11/30/2009 12:33:11 PM 1222 0 1268 957 0x0 0x0 - 11/30/2009 12:33:11 PM x.x.x.x 172.29.49.10 80 HTTP Closed Connection 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN Internal Local Host - ISA Firewall
x.x.x.x - TCP - - - 11/30/2009 12:33:11 PM 1223 0 0 0 0x0 0x0 - 11/30/2009 12:33:11 PM x.x.x.x 172.29.49.10 80 HTTP Initiated Connection 0x0 ERROR_SUCCESS Internal Local Host - ISA Firewall
x.x.x.x - TCP - - - 11/30/2009 12:33:11 PM 1224 0 0 0 0x0 0x0 - 11/30/2009 12:33:11 PM x.x.x.x 172.29.49.10 80 HTTP Initiated Connection 0x0 ERROR_SUCCESS Internal Local Host - ISA Firewall
x.x.x.x - TCP - - - 11/30/2009 12:33:11 PM 1225 0 0 0 0x0 0x0 - 11/30/2009 12:33:11 PM x.x.x.x 172.29.49.10 80 HTTP Initiated Connection 0x0 ERROR_SUCCESS Internal Local Host - ISA Firewall
Many thanks!"
Marc
RE: WebDav - Problem with one filetype - 30.Nov.2009 6:02:31 PM
Try this?
http://www.microsoft.com/technet/prodtechnol/WindowsServer2003/Library/IIS/cd72c0dc-c5b8-42e4-96c2-b3c656f99ead.mspx?mfr=true
If not, check NTFS perms for the .cfm files for the user you are authenticating as...
(in reply to mturner)
RE: WebDav - Problem with one filetype - 1.Dec.2009 12:04:17 PM
mturner
HI
Thanks very much for your reply. i think ive ruled out the ISA being the problem now as i connected a PC behind the ISA and mapped directly to the server and still had the problem.
This means the issue is with the server / IIS, as this is an ISA fourm ill keep quiet now. although when i work out what my issue is ill post back my findings!.
On a side note, the permissions and MIME types are fine, im very confused!
cheers!
Marc
