Web Browsing through 3rd NIC
Web Browsing through 3rd NIC - 19.Jun.2007 12:24:04 AM
mkleinpaste
Hi, I just started setting up my new ISA Server 2006 Standard for our edge network. It's gone pretty well so far, however, I have run into a stumbling block I was hoping you experts could help me with. Here's the scenario. We have your normal web services going through a bonded T-1 connection along with our Uber important VPN connections to our 50+ client sites. However, we also have a cable modem that we have historically used for "Web Browsing", etc. (the fun stuff) to minimize the amount of bandwidth we use from our more expensive T-1 for "Non-Business" activities that we allow to keep moral up such as YouTube. I would like to do the same with the ISA Server. I have it connected the ISA Server to our Internal LAN, our External T-1 and our Cable Modem. The LAN and T-1 are static addresses while the Cable Modem runs on DHCP and has successfully obtained an IP Address. I tried creating a new network using the "Cable Modem" NIC and applying an Access Rule that allows the "Fun Stuff" from Internal Network to the Cable Modem Network. Alas, this did not work, so obviously I'm missing something here. If anyone has some insight into making this work please let me know. Otherwise I'll scrap the Cable Modem and at least we'll save a few bucks a month without it. Thanks in advance to whomever brings the successful resolution of this! Michael
< Message edited by mkleinpaste -- 19.Jun.2007 12:32:01 AM >
RE: Web Browsing through 3rd NIC - 26.Jun.2007 3:31:21 AM
alex3299
You donīt have to buy any additional hardware to put this working, the ISA server in this case must have 3 NICS, 1 for the T1, 1 for the cable modem and 1 for the internal LAN, when you install ISA you define your internal network, and all the other nics are members of the External network, now you just have to create another external network, use the cable modem nic and allow the traffic based on protocol, FQDN, IP, on it... If you donīt set the Network Rules on the Configuration\Networks, your network will not work.
RE: Web Browsing through 3rd NIC - 28.Jun.2007 3:29:02 AM
mzakir
Hi Alex, Can you describe this solution in details? If possible pls show us snapshot.. Thanks
Malek Zakir MCP,MCSA:Security,MCSA:Messaging,MCTS,CCNA,DCH
RE: Web Browsing through 3rd NIC - 25.Jul.2008 2:27:07 PM
mkleinpaste
Hi Alex, How did you accomplish this. I found where you can add an adapter as an external network in the "Networks" tab. How did you route all the internal traffic that you don't want heading to the main line to the secondary line? Details would be great! Thanks.
RE: Web Browsing through 3rd NIC - 27.Jul.2008 6:08:50 PM
royh
Hi Guys, Keep in mind that ISA doesn't support mutliple gateways!!! You can't use your T1 line and cable modem together. Thanks -
Roy Haddad,M.Sc CCNA, MCSE 2003 Messaging & Security,C|EH
