Web Proxy Error 12202
All Forums >> [ISA Server 2004 Cache] >> Web Proxy client >> Web Proxy Error 12202 Page: [1] 2   next >   >>
Web Proxy Error 12202 - 10.Sep.2007 8:07:19 AM
andrewwillett
We sporadically have web proxy clients on the network failing to connect to the internet through the ISA Server with error:
Error Code: 403 Forbidden. The ISA Server denied the specified Uniform Resource Locator (URL). (12202).
The error is a white page with black text, not the ISA Server-style error page with the red banner at the top.
The clients are set to automatically detect settings, and I have published the ISA Server routing script in DHCP. When I take off automatically detect settings and manually specify the URL to array.dll?Get.Routing.Script etc the error is still apparant.
There is a rule to allow all authenticated users access to HTTP, FTP and HTTPS which is working for the vast majority of users. We just have a handful of clients that are getting this error, and I can't understand why this would randomly happen to some clients.
Any help would be most appreciated!
Kind Regards,
Andrew Willett
Systems Architect
RE: Web Proxy Error 12202 - 10.Sep.2007 12:53:11 PM
Rotorblade
Status: online
Hi Andrew,
Assuming that you are running ISA SP 3; what’s diagnostic logging show?
RB
(in reply to andrewwillett)
RE: Web Proxy Error 12202 - 13.Dec.2007 6:22:57 AM
dmecha
Hi andrew,
I have the same issue as you , just browsing some sites, for example www.easyjet.com, I can reach that page but after clicking one of the links there it displays the same error as you are saying.
Any idea?
Daniel.
RE: Web Proxy Error 12202 - 26.Dec.2007 11:16:30 AM
abqtech
Do you have the Microsoft Firewall Client deployed to workstations on your network?
(in reply to dmecha)
RE: Web Proxy Error 12202 - 26.Dec.2007 11:18:26 AM
dmecha
Yes we have it.
(in reply to abqtech)
RE: Web Proxy Error 12202 - 26.Dec.2007 11:52:53 AM
abqtech
If you're sure that the 403 forbidden errors are coming from ISA, perhaps the client is making a request as a firewall client, rather than a web proxy client.   Have you gone into the Monitoring -> Logging within ISA and run a query including the:
firewall or web proxy filter and the  client IP addresss?  What results did you get?
RE: Web Proxy Error 12202 - 27.Dec.2007 3:27:25 AM
dmecha
If I activate logging , the HTTP Status code "12202 The ISA Server denied the specified Uniform Resource Locator (URL). " is a Web Proxy Log Record Type.
But when requesting this page (www.easyjet.com) I see also Firewall logs, that are not present when I rquest other webpages. What does it mean?
RE: Web Proxy Error 12202 - 27.Dec.2007 9:56:45 AM
abqtech
The other firewall log types are more than likely the tcp connections being used for the HTTP traffic.  (If you have ISA 2004 SP3, you'll see greater detail within the ISA logging).
What "Rule" is the "12202 The ISA Server denied the specified Uniform Resource Locator (URL)" log entry associated with?  Please document how that Firewall Access Rule is configured.
Noteworthy:
DNS respones to www.easyjet.com result in multiple DNS records on different networks.
www.easyjet.com. 1800 IN CNAME www.easyjet.com.nsatc.net.
www.easyjet.com.nsatc.net. 30 IN A 213.174.196.170
www.easyjet.com. 1750 IN CNAME www.easyjet.com.nsatc.net.
www.easyjet.com.nsatc.net. 30 IN A 165.193.172.182
Do you have any configuration on your ISA Server that accounts for either of these addresses?:
213.174.196.170
165.193.172.182
RE: Web Proxy Error 12202 - 27.Dec.2007 10:52:34 AM
dmecha
We called this rule "Deny HTTP through Firewall Client", and what it does is to deny HTTP on Port 80 from our internal network to the internet, to because FWC client enabled sends PORT 80 traffic instead of HTTP and so our webfilter (Websense)wouldn´t intercept it.
In the other hand the IP that DNS is resolving is165.193.172.182.
RE: Web Proxy Error 12202 - 27.Dec.2007 11:03:44 AM
abqtech
how is your client setup?  Browser/Proxy settings Firewall client (enabled/disabled):
Also check out my last post: (it speaks directly to firewall client HTTP traffic and web filtering bypass, such as what you've done to prevent the bypassing of your websense infrastructure)
http://forums.isaserver.org/ISA_2K6_%26_Firewall_Client_HTTP_Redirection/m_2002058424/tm.htm
RE: Web Proxy Error 12202 - 27.Dec.2007 11:15:46 AM
dmecha
The proxy settings are enabled.
-My rule seems to be similar that the one you suggests on the linked post, the only difference is that I apply it for all kind of traffic to All Users instead of  having a different rule for audio and video.
< Message edited by dmecha -- 27.Dec.2007 11:20:08 AM >
RE: Web Proxy Error 12202 - 27.Dec.2007 11:20:15 AM
abqtech
could you please, ensure that your firewall client is disabled, and that your able to access some other HTTP site (i.e. http://www.google.com) and then try the problem site again (all while running the ISA logging on your client IP address) and then copy the ISA log in your reply.
RE: Web Proxy Error 12202 - 27.Dec.2007 12:02:04 PM
dmecha
I can visit other webpages disabling FW Client, but when accesing easyjet site and searching for an available flight (same action than before) it also fails.
Now the error is IE "cannot open the webpage".
I have the logs saved on an excell file , Shall I send them by email to you as they are a lot of lines or do you want me to paste just the error line?
RE: Web Proxy Error 12202 - 27.Dec.2007 1:02:40 PM
abqtech
Just paste them into this thread, please.
RE: Web Proxy Error 12202 - 27.Dec.2007 1:06:57 PM
abqtech
Also when you stated that the proxy settings are enabled.  Does that mean that your browser is using some type of automatic configuration (WPAD or routing script?) or do you have the "Use Proxy Server for your LAN" checked?  Do you have any entries added in the "bypass proxy server for local addresses" field
RE: Web Proxy Error 12202 - 28.Dec.2007 3:16:22 AM
dmecha
Yes my browser settings are set to Automatically detect settings, use the automatic configuration script and use a Web proxy server. Also Bypass the proxy for local addresses.
Here is the log:
Original Client IP Client Agent Authenticated Client Service Server Name Referring Server Destination Host Name Transport MIME Type Object Source Source Proxy Destination Proxy Bidirectional Client Host Name Filter Information Network Interface Raw IP Header Raw Payload GMT Log Time Source Port Processing Time Bytes Sent Bytes Received Result Code HTTP Status Code Cache Information Error Information Log Record Type Authentication Server Log Time Destination IP Destination Port Protocol Action Rule Client IP Client Username Source Network Destination Network HTTP Method URL
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER  www.google.es TCP   - -  - Req ID: 12297a6b; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:06:44 AM 0 1 4601 789  12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  0x0 0x800 Web Proxy Filter  12/28/2007 9:06:44 AM 10.135.1.19 8080 http Denied Connection Full Outbound 10.135.6.11 anonymous Internal External GET http://www.google.es/
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER  www.google.es TCP   - -  - Req ID: 12297a6c; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:06:44 AM 0 1 654 909  5 Access is denied.  0x0 0x880 Web Proxy Filter  12/28/2007 9:06:44 AM 10.135.1.19 8080 http Failed Connection Attempt Full Outbound 10.135.6.11 anonymous Internal External GET http://www.google.es/
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER  www.google.es TCP text/html; charset=UTF-8 Internet - -  - Req ID: 12297a6d; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:06:45 AM 0 453 6878 1465  200 OK. 0x60020000 0x480 Web Proxy Filter  12/28/2007 9:06:45 AM 64.233.167.147 80 http Allowed Connection Full Outbound 10.135.6.11 domain\username Internal External GET http://www.google.es/
10.135.6.11    PROXYSERVER -  TCP -    Yes  -    12/28/2007 8:06:46 AM 63221 0 0 0 0x0 ERROR_SUCCESS  0x0 0x0 Firewall - 12/28/2007 9:06:46 AM 10.135.1.19 8080 HTTP Proxy Initiated Connection  10.135.6.11  Internal Local Host - -
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER  www.easyjet.com TCP text/html Internet - -  - Req ID: 12297a6e; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:06:59 AM 0 63 470 751  302 Moved Temporarily 0x42020000 0x480 Web Proxy Filter  12/28/2007 9:06:59 AM 165.193.172.182 80 http Allowed Connection Full Outbound 10.135.6.11 domain\username Internal External GET http://www.easyjet.com/
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER  www.easyjet.com TCP text/html Internet - -  - Req ID: 12297a76; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:06:59 AM 0 63 506 801  302 Moved Temporarily 0x42020000 0x480 Web Proxy Filter  12/28/2007 9:06:59 AM 165.193.172.182 80 http Allowed Connection Full Outbound 10.135.6.11 domain\username Internal External GET http://www.easyjet.com/es/
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP   - -  - Req ID: 12297a79; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:06:59 AM 0 1 4601 740  12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  0x1002 0x800 Web Proxy Filter  12/28/2007 9:06:59 AM 10.135.1.19 8080 http Denied Connection Full Outbound 10.135.6.11 anonymous Internal External GET http://www.easyjet.com/common/css/global.css
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP   - -  - Req ID: 12297a7a; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:06:59 AM 0 1 654 860  5 Access is denied.  0x1002 0x880 Web Proxy Filter  12/28/2007 9:06:59 AM 10.135.1.19 8080 http Failed Connection Attempt Full Outbound 10.135.6.11 anonymous Internal External GET http://www.easyjet.com/common/css/global.css
10.135.6.11    PROXYSERVER -  TCP -    Yes  -    12/28/2007 8:06:59 AM 63225 0 0 0 0x0 ERROR_SUCCESS  0x0 0x0 Firewall - 12/28/2007 9:06:59 AM 10.135.1.19 8080 HTTP Proxy Initiated Connection  10.135.6.11  Internal Local Host - -
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER  www.easyjet.com TCP text/html; Charset=UTF-8 Internet - -  - Req ID: 12297a77; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:00 AM 0 797 63674 901  200 OK. 0x40020000 0x480 Web Proxy Filter  12/28/2007 9:07:00 AM 165.193.172.182 80 http Allowed Connection Full Outbound 10.135.6.11 domain\username Internal External GET http://www.easyjet.com/es/Reserve/index.asp
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP text/css Verify Failed Internet - -  - Req ID: 12297a7c; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:00 AM 0 78 2012 743  200 OK. 0xa01002 0x480 Web Proxy Filter  12/28/2007 9:07:00 AM 165.193.172.182 80 http Allowed Connection Full Outbound 10.135.6.11 domain\username Internal External GET http://www.easyjet.com/common/css/hotelopia.css
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP text/css Verified Cache - -  - Req ID: 12297a7d; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:00 AM 0 62 319 743  304 Not Modified 0xa01002 0x480 Web Proxy Filter  12/28/2007 9:07:00 AM 165.193.172.182 80 http Allowed Connection Full Outbound 10.135.6.11 domain\username Internal External GET http://www.easyjet.com/common/css/ej_booking.css
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP text/css Verify Failed Internet - -  - Req ID: 12297a7b; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:00 AM 0 735 69343 1416  200 OK. 0xa01002 0x480 Web Proxy Filter  12/28/2007 9:07:00 AM 165.193.172.182 80 http Allowed Connection Full Outbound 10.135.6.11 domain\username Internal External GET http://www.easyjet.com/common/css/global.css
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP text/css Verified Cache - -  - Req ID: 12297a7e; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:00 AM 0 78 319 746  304 Not Modified 0xa01002 0x480 Web Proxy Filter  12/28/2007 9:07:00 AM 165.193.172.182 80 http Allowed Connection Full Outbound 10.135.6.11 domain\username Internal External GET http://www.easyjet.com/common/css/ej_bookingIE7.css
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP application/x-javascript Verified Cache - -  - Req ID: 12297a7f; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:00 AM 0 78 319 741  304 Not Modified 0xa01002 0x480 Web Proxy Filter  12/28/2007 9:07:00 AM 165.193.172.182 80 http Allowed Connection Full Outbound 10.135.6.11 domain\username Internal External GET http://www.easyjet.com/common/js/ej_booking.js
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP text/css Verified Cache - -  - Req ID: 12297a80; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:00 AM 0 62 320 749  304 Not Modified 0xa01002 0x480 Web Proxy Filter  12/28/2007 9:07:00 AM 165.193.172.182 80 http Allowed Connection Full Outbound 10.135.6.11 domain\username Internal External GET http://www.easyjet.com/common/css/ej_bookingLogin.css
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP text/css Verified Cache - -  - Req ID: 12297a81; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:00 AM 0 63 320 750  304 Not Modified 0xa01002 0x480 Web Proxy Filter  12/28/2007 9:07:00 AM 165.193.172.182 80 http Allowed Connection Full Outbound 10.135.6.11 domain\username Internal External GET http://www.easyjet.com/common/css/ej_headerCorners.css
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP application/x-javascript Verify Failed Internet - -  - Req ID: 12297a82; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:00 AM 0 78 2916 744  200 OK. 0xa01002 0x480 Web Proxy Filter  12/28/2007 9:07:00 AM 165.193.172.182 80 http Allowed Connection Full Outbound 10.135.6.11 domain\username Internal External GET http://www.easyjet.com/touchclarity/logging.js
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP application/x-javascript Verify Failed Internet - -  - Req ID: 12297a83; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:00 AM 0 109 6037 746  200 OK. 0xa01002 0x480 Web Proxy Filter  12/28/2007 9:07:00 AM 165.193.172.182 80 http Allowed Connection Full Outbound 10.135.6.11 domain\username Internal External GET http://www.easyjet.com/touchclarity/logging-code.js
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp easyjet.touchclarity.com TCP image/gif Internet - -  - Req ID: 12297a85; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:00 AM 0 93 720 723  200 OK. 0x43860000 0x480 Web Proxy Filter  12/28/2007 9:07:00 AM 213.52.219.17 80 http Allowed Connection Full Outbound 10.135.6.11 domain\username Internal External GET http://easyjet.touchclarity.com/i?siteID=250&ts=1198829219818&location=http%3A%2F%2Fwww.easyjet.com%2Fes%2FReserve%2Findex.asp&tagv=3.4&tz=60&r=empty&title=easyJet.com%20-%20reserve%20billetes%20de%20avi%C3%B3n%20baratos%2C%20hoteles%20y%20alquiler%20de%20veh%C3%ADculo%20en%20l%C3%ADnea&cd=32&ah=994&aw=1280&sh=1024&sw=1280&pd=undefined
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP application/x-javascript Verify Failed Internet - -  - Req ID: 12297a84; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:00 AM 0 156 14534 739  200 OK. 0xa01002 0x480 Web Proxy Filter  12/28/2007 9:07:00 AM 165.193.172.182 80 http Allowed Connection Full Outbound 10.135.6.11 domain\username Internal External GET http://www.easyjet.com/Common/js/WebTrends.js
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP image/gif Verify Failed Internet - -  - Req ID: 12297a86; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 78 1882 747  200 OK. 0xa01002 0x480 Web Proxy Filter  12/28/2007 9:07:01 AM 165.193.172.182 80 http Allowed Connection Full Outbound 10.135.6.11 domain\username Internal External GET http://www.easyjet.com/common/img/page/logo_main.gif
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP image/gif Verified Cache - -  - Req ID: 12297a88; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 62 319 746  304 Not Modified 0xa01002 0x480 Web Proxy Filter  12/28/2007 9:07:01 AM 165.193.172.182 80 http Allowed Connection Full Outbound 10.135.6.11 domain\username Internal External GET http://www.easyjet.com/common/img/page/chevrons.gif
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER  fls.doubleclick.net TCP  Internet - -  - Req ID: 12297a8b; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 0 1199 0  407 Proxy Authentication Required 0x0 0x0 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 443 SSL-tunnel Allowed Connection Full Outbound 10.135.6.11 anonymous Internal External  fls.doubleclick.net:443
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER  fls.doubleclick.net TCP  Internet - -  - Req ID: 12297a8b; Req ID: 12297a8b; Compression: client=No, server=No, compress rate=0% decompress rate=0%, Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 0 1199 0  407 Proxy Authentication Required 0x0 0x0 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 443 SSL-tunnel Allowed Connection Full Outbound 10.135.6.11 anonymous Internal External  fls.doubleclick.net:443
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP   - -  - Req ID: 12297a8d; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 1 4601 739  12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  0x1002 0x800 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 8080 http Denied Connection Full Outbound 10.135.6.11 anonymous Internal External GET http://www.easyjet.com/common/img/flagES.gif
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER  fls.doubleclick.net TCP  Internet - -  - Req ID: 12297a90; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 0 654 0  407 Proxy Authentication Required 0x0 0x800 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 443 SSL-tunnel Allowed Connection Full Outbound 10.135.6.11 anonymous Internal External  fls.doubleclick.net:443
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER  fls.doubleclick.net TCP  Internet - -  - Req ID: 12297a90; Req ID: 12297a90; Compression: client=No, server=No, compress rate=0% decompress rate=0%, Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 0 654 0  407 Proxy Authentication Required 0x0 0x800 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 443 SSL-tunnel Allowed Connection Full Outbound 10.135.6.11 anonymous Internal External  fls.doubleclick.net:443
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER  fls.doubleclick.net TCP   - -  - Req ID: 12297a91; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 1 145 969  12210 An Internet Server API (ISAPI) filter has finished handling the request. Contact your system administrator.  0x0 0x80 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 443 SSL-tunnel Failed Connection Attempt  10.135.6.11 domain\username Internal  CONNECT
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP   - -  - Req ID: 12297a93; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 1 4601 758  12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  0x1002 0x800 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 8080 http Denied Connection Full Outbound 10.135.6.11 anonymous Internal External GET http://www.easyjet.com/common/img/ES_alert_Holidays_191107.jpg
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP   - -  - Req ID: 12297a94; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 1 4601 755  12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  0x1002 0x880 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 8080 http Denied Connection Full Outbound 10.135.6.11 anonymous Internal External GET http://www.easyjet.com/common/img/page/tab_L_1_first_off.jpg
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP   - -  - Req ID: 12297a95; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 1 4601 753  12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  0x1002 0x880 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 8080 http Denied Connection Full Outbound 10.135.6.11 anonymous Internal External GET http://www.easyjet.com/common/img/icons/icon_hotel_off.gif
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP   - -  - Req ID: 12297a96; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 1 4601 749  12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  0x1002 0x880 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 8080 http Denied Connection Full Outbound 10.135.6.11 anonymous Internal External GET http://www.easyjet.com/common/img/page/tab_R_1_off.jpg
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP   - -  - Req ID: 12297a97; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 1 4601 749  12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  0x1002 0x880 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 8080 http Denied Connection Full Outbound 10.135.6.11 anonymous Internal External GET http://www.easyjet.com/common/img/page/tab_L_1_off.jpg
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP   - -  - Req ID: 12297a98; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 1 4601 751  12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  0x1002 0x880 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 8080 http Denied Connection Full Outbound 10.135.6.11 anonymous Internal External GET http://www.easyjet.com/common/img/icons/icon_car_off.gif
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP   - -  - Req ID: 12297a99; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 1 4601 657  12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  0x0 0x880 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 8080 http Denied Connection Full Outbound 10.135.6.11 anonymous Internal External GET http://www.easyjet.com/common/img/icons/cross.gif
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP   - -  - Req ID: 12297a9a; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 1 4601 665  12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  0x0 0x880 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 8080 http Denied Connection Full Outbound 10.135.6.11 anonymous Internal External GET http://www.easyjet.com/common/img/icons/icon_park_off.gif
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP   - -  - Req ID: 12297a9b; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 1 4601 666  12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  0x0 0x880 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 8080 http Denied Connection Full Outbound 10.135.6.11 anonymous Internal External GET http://www.easyjet.com/common/img/icons/icon_trans_off.gif
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP   - -  - Req ID: 12297a9c; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 1 4601 667  12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  0x0 0x880 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 8080 http Denied Connection Full Outbound 10.135.6.11 anonymous Internal External GET http://www.easyjet.com/common/img/icons/icon_lounge_off.gif
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP   - -  - Req ID: 12297a9d; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 1 4601 661  12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  0x0 0x880 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 8080 http Denied Connection Full Outbound 10.135.6.11 anonymous Internal External GET http://www.easyjet.com/common/img/page/tab_L_1_on.jpg
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP   - -  - Req ID: 12297a9e; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 1 4601 666  12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  0x0 0x880 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 8080 http Denied Connection Full Outbound 10.135.6.11 anonymous Internal External GET http://www.easyjet.com/common/img/icons/icon_flight_on.gif
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP   - -  - Req ID: 12297a9f; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 1 4601 666  12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  0x0 0x880 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 8080 http Denied Connection Full Outbound 10.135.6.11 anonymous Internal External GET http://www.easyjet.com/common/img/page/tab_R_1_last_on.jpg
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP   - -  - Req ID: 12297aa0; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 1 4601 664  12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  0x0 0x880 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 8080 http Denied Connection Full Outbound 10.135.6.11 anonymous Internal External GET http://www.easyjet.com/common/img/ES-L2-Hotesl211207.jpg
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP   - -  - Req ID: 12297aa1; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 1 4601 658  12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  0x0 0x880 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 8080 http Denied Connection Full Outbound 10.135.6.11 anonymous Internal External GET http://www.easyjet.com/common/img/ES-L3-SBplus.jpg
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP   - -  - Req ID: 12297aa2; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 1 4601 660  12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  0x0 0x880 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 8080 http Denied Connection Full Outbound 10.135.6.11 anonymous Internal External GET http://www.easyjet.com/common/img/icons/icon_cal.gif
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP   - -  - Req ID: 12297aa3; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 1 4601 665  12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  0x0 0x880 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 8080 http Denied Connection Full Outbound 10.135.6.11 anonymous Internal External GET http://www.easyjet.com/common/img/ES-R4-Tangier211207.jpg
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP   - -  - Req ID: 12297aa4; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 1 4601 750  12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  0x1002 0x880 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 8080 http Denied Connection Full Outbound 10.135.6.11 anonymous Internal External GET http://www.easyjet.com/common/img/ES-R5-Amor151107.jpg
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP   - -  - Req ID: 12297aa5; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 1 4601 663  12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  0x0 0x880 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 8080 http Denied Connection Full Outbound 10.135.6.11 anonymous Internal External GET http://www.easyjet.com/common/img/eOffers_logoutbox.gif
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP   - -  - Req ID: 12297aa6; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 1 4601 660  12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  0x0 0x880 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 8080 http Denied Connection Full Outbound 10.135.6.11 anonymous Internal External GET http://www.easyjet.com/common/img/page/header_bg.gif
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP   - -  - Req ID: 12297aa7; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 1 4601 746  12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  0x1002 0x880 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 8080 http Denied Connection Full Outbound 10.135.6.11 anonymous Internal External GET http://www.easyjet.com/common/img/page/tab_BG_1.jpg
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP   - -  - Req ID: 12297aa8; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 1 4601 749  12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  0x1002 0x880 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 8080 http Denied Connection Full Outbound 10.135.6.11 anonymous Internal External GET http://www.easyjet.com/common/img/page/tab_BG_1_on.jpg
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP   - -  - Req ID: 12297aa9; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 1 4601 747  12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  0x1002 0x880 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 8080 http Denied Connection Full Outbound 10.135.6.11 anonymous Internal External GET http://www.easyjet.com/common/img/modulepromo_bg.jpg
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp statse.webtrendslive.com TCP image/gif Internet - -  - Req ID: 12297a87; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 266 673 1137  200 OK. 0x43040000 0x480 Web Proxy Filter  12/28/2007 9:07:01 AM 63.236.111.50 80 http Allowed Connection Full Outbound 10.135.6.11 domain\username Internal External GET http://statse.webtrendslive.com/dcsstxwbf10000sxorp4g04rs_5d5t/dcs.gif?&dcsdat=1198829220017&dcssip=www.easyjet.com&dcsuri=/es/Reserve/index.asp&WT.co_f=62.22.30.34-2300859648.29866187&WT.vt_sid=62.22.30.34-2300859648.29866187.1198829220053&WT.vt_f_tlv=1198772781&WT.tz=1&WT.bh=9&WT.ul=es&WT.cd=32&WT.sr=1280x1024&WT.jo=Yes&WT.ti=easyJet.com%20-%20reserve%20billetes%20de%20avión%20baratos,%20hoteles%20y%20alquiler%20de%20vehículo%20en%20línea&WT.js=Yes&WT.jv=1.3&WT.ct=unknown&WT.fi=Yes&WT.fv=9.0&WT.tv=8.0.2&WT.vt_f_tlh=1198775021&WT.vt_f_d=1&WT.vt_f_s=1&display_language=ES
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP   - -  - Req ID: 12297aaa; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 1 4601 660  12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  0x0 0x880 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 8080 http Denied Connection Full Outbound 10.135.6.11 anonymous Internal External GET http://www.easyjet.com/common/img/page/right_tab.gif
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP   - -  - Req ID: 12297aac; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 1 4601 673  12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  0x0 0x880 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 8080 http Denied Connection Full Outbound 10.135.6.11 anonymous Internal External GET http://www.easyjet.com/common/img/page/tab_select_left_middle.gif
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP   - -  - Req ID: 12297aad; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 1 4601 670  12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  0x0 0x880 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 8080 http Denied Connection Full Outbound 10.135.6.11 anonymous Internal External GET http://www.easyjet.com/common/img/page/tab_select_left_top.gif
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP   - -  - Req ID: 12297aae; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 1 4601 748  12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  0x1002 0x880 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 8080 http Denied Connection Full Outbound 10.135.6.11 anonymous Internal External GET http://www.easyjet.com/common/img/page/img_footer.gif
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 1.1.4322; MS-RTC LM 8) Yes Proxy PROXYSERVER http://www.easyjet.com/es/Reserve/index.asp www.easyjet.com TCP   - -  - Req ID: 12297aaf; Compression: client=No, server=No, compress rate=0% decompress rate=0% - - - 12/28/2007 8:07:01 AM 0 1 4601 660  12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  0x0 0x880 Web Proxy Filter  12/28/2007 9:07:01 AM 10.135.1.19 8080 http Denied Connection Full Outbound 10.135.6.11 anonymous Internal External GET http://www.easyjet.com/common/img/pag
