Web Publishing
All Forums >> [ISA Server 2000 General] >> Web Publishing >> Web Publishing Page: [1]
Web Publishing - 15.Jun.2001 1:07:00 PM
Ulf Gshlin
Are there any known problems with multiple destinations in a destionation set?
I'm trying to publish OWA and have followed the guide in the excellent learning section on this site. For some reason, I will always receive the following error when trying to access OWA:
"403 Forbidden - The server denies the specified Uniform Resource Locator (URL). Contact the server administrator. (12202)
Internet Security and Acceleration Server"
The Web Publishing rule for OWA uses following destination set:
Name/IP Range: Path:
<FQDN of ext. IP> /exchange/*
<FQDN of ext. IP> /exchweb/*
I have tried to redirect to both the FQDN on the internal web as well as the internal IP, using both original headers and not, but I can't get it to work. However, if I remove all destinations but one (leavinging the '/exchange/*' entry) ISA will let me through to the internal webserver, but OWA wont work since it needs access to the '/exchweb' folder. Adding another destination set with '/exchweb/*' and another web publish rule using this set will give full access to OWA, but why the heck can't I use two or more destinations in a set?? Two web publishing rules and two destination set should be neccessary?
Have a nice weekend!
/Ulf
RE: Web Publishing - 17.Jun.2001 5:49:00 PM
jtaylor
Ulf,
See the topic in this group titled "403 Forbidden - error on all external HTTP requests." You might find the answer there.
JT
(in reply to Ulf Gshlin)
RE: Web Publishing - 18.Jun.2001 11:32:00 AM
Ulf Gshlin
Thanks JT,
I have read the thread but I can't find a suitable answer..
My publishing works as long as I have only one destination in a destination set. As soon as I add more that one destination, L'll get the "403 Forbidden" error, but using two destination sets and two web publishing rules to accomplish the same thing works perfectly..
Other suggestion..?
/Ulf
RE: Web Publishing - 18.Jun.2001 5:44:00 PM
Paul Tark
Ulf,
I known it's not much help but I am suffering the EXACT same problem here. I'm rapidly comming to the conclusion that multiple paths just does not work. If you do find a solution I would love to know the answer.
Regards
Paul.
RE: Web Publishing - 18.Jun.2001 6:51:00 PM
jtaylor
Hmm, Ulf, sorry, I don't have any other suggestions.
JT
