Web Publishing / RRAS wierdness
Web Publishing / RRAS wierdness - 11.Feb.2004 3:03:00 AM
adidell
Hey,
I am having a couple strange issues with Beta 2 of ISA 2004. Of course, this is not surprising in a beta 2 release, but I am curious if anyone else has had this happen.
I am running a lab ISA on a:
500 Mhz Pentium III Dual 100Mb NICs 384 Mb RAM Windows 2003 Enterprise Ed.
The 2 issues I have had are:
1. If I make any change to the firewall rules, ISA seems to want to flip the RRAS setting regarding use of DHCP vs. a IP Range for RRAS VPN clients. To work around this, I setup DHCP on another box on that subnet to get around the issue. Also, it might be worth reminding admins in the docs that they need to:
a. Setup DHCP Relay Agent in RRAS and add the ôInternalö virtual interface in RRAS to that Routing Protocol. b. Also, a firewall rule to allow the DHCP protocols needs to be setup from the LocalHost to the IP of the DHCP server. Otherwise, in RRAS and therefore to clients trying to VPN in they get an auto-assigned IP instead of one from the DHCP scope.
2. I had a web publishing rule setup for my web site, and it was working perfectly. The rule was just passing HTTP (ie. No SSL or SSL bridging). Now, no matter what I do, it shows a message from any network that ISA is blocking that URL, as if I had typed it incorrectly. I have it set now to no longer restrict based on the public name, so IÆm stumped. I have an OWA rule allowing access to OWA from the VPN clients network only, and that seems to work.
Any help on this would be appreciated!
RE: Web Publishing / RRAS wierdness - 17.Feb.2004 12:29:00 PM
Status: online
Hi Andrew,
Me too!
