Web Publishing Error Code 64 Host not available
Web Publishing Error Code 64 Host not available - 18.Nov.2008 12:51:36 PM
onesquin
I just recently swapped out hardware for our ISA Server. Technically everything in our environment is the same except The ISA Server with the fundamental difference being the old server was 2006 SP0 and the new server is ISA 2006 SP1. All of the rules were imported. Before we did not have any problems publishing a web server that serves out several applications. Here are the details on the server Windows Server 2003 R2 It is using an IIS Connector to serve Apache Tomcat(v5) based applications. The applications are Atlassian Confluence and Atlassian Jira. Basically after clicking around for a while after logging in there will be an Error Code 64 Host not available on the browser. The corresponding error on the ISA server log is a Failed Connection Attempt with status Status: 64 The specified network name is no longer available. This is 100% repeatable for both of the applications. There is zero problem with the applications internally. I have created new publishing rules and the same has happened I have changed the keepalives for IIS and nothing. I have tried all four combinations of the Forward Orig Host header and Proxy requests to published site under the TO tab of the publish rule with no luck. There are some errors in the ISAPI connector log, but it is not consistent with the errors. Any help would be greatly appreciated. I might have forgotten some info, let me know if you need anything else.
RE: Web Publishing Error Code 64 Host not available - 21.Nov.2008 11:18:21 AM
preeves
Hmmmm, I have a similar problem, with a site that has multiple images on 1 page, only 1 or two of the thumbnails will load, the rest show as broken links along with the status 64 error in the isa log. Reloading the page (not refreshing the page) causes another couple of the thumbnails to load. There is also a similar problem a few below this post. I do have EnableRSS = 0 in the registry (on ISA), and I do have other sites which as far as I know do not have this problem, although on other IIS servers. Paul
RE: Web Publishing Error Code 64 Host not available - 21.Nov.2008 11:36:06 AM
onesquin
I am pretty sure we have it narrowed down to the NTLM authentication. We are working through it right now. Will update you if a definitive answer is found.
RE: Web Publishing Error Code 64 Host not available - 21.Nov.2008 5:01:38 PM
jhood
I been working with onesquin on this problem and tried the rss fix but no love. Breakdown.. If the published rule is set to all users, then the site comes through without a problem. If the published rule is set to authenticated users using the HTML form based authentication, then the site comes through, BUT gives a host not found error on the 2nd or 3rd link you click on. We have other sites working like exchange owa, it is just the websites using the Tomcat java server that are having problems. However it was working perfectly for months till we upgraded the hardware, along with sp1 for isa 2006. The "test run" button of the rule comes back positive, as expected since it takes 2 or 3 clicks on the site to break. -isa server SSL listener using forms based authentication -web server - iis redirecting to Tomcat that redirects back iis. exact error code is : 64 Host not available, the connection to the web server was lost.
RE: Web Publishing Error Code 64 Host not available - 25.Nov.2008 7:53:05 AM
Status: online
Hi J, It might be related to the Java app and changes make with SP1. You might want to check and see if it works if you remove SP1 -- that way you can isolate that vairable and let PSS know that it's a SP1 issue. If removing SP1 doesn't fix it, then it might be a bug in the Web site. HTH, Tom
RE: Web Publishing Error Code 64 Host not available - 25.Nov.2008 9:03:09 AM
onesquin
Actually it was the NTLM authentication. We removed the NTLM authentication from the publishing rule and changed it to No authentication. We simply set the listener to do the authentication. Something must have slightly changed in SP1 to cause it to work a little differently.
RE: Web Publishing Error Code 64 Host not available - 28.Nov.2008 10:09:19 AM
Status: online
Just so that I have this striaght -- NTLM auth was enabled on the listener. We're you forcing authentication at the listener or on the Web Publshing Rule? Thanks! Tom
RE: Web Publishing Error Code 64 Host not available - 5.Dec.2008 10:23:18 AM
yeskaygee1
Hello, I am new to this forum and I would like to report a similar problem on this with a different settings 1 - The listener is configured without SSL and with no authentication 2 - The access is restricted to a specific group of hosts 3 - The connection works for all but few (3 to 4) hosts. The error messages returned from the ISA logs are either or both of the below Status: 64 The specified network name is no longer available Status: 1460 This operation returned because the timeout period expired I am really not sure if it is related to what you are already checking. But any pointers would really help. Regards, Karthigeyan
RE: Web Publishing Error Code 64 Host not available - 8.Dec.2008 9:24:34 AM
jhood
Yes, the web publishing rule had NTLM enabled, but it was never doing anything since the webserver didnt have NTLM enabled. However, we didnt want to rely on the java server(Tomcat) for security(it has a login page too), so leaving NTLM on the listener got us what we wanted. What appears to happen, if you have NTLM on the publishing rule, but not on the webserver, ISA will show you 2 or 3 pages. Then ISA will kill the connection, but erroneously tell you connection was lost to the webserver. Before sp1, ISA would allow this behaviour
RE: Web Publishing Error Code 64 Host not available - 8.Dec.2008 11:42:25 AM
yeskaygee1
This error is reported on an inbound access. To be more clear on the scenario below are the details and problem description 1 - The internal server has got multiple portals (portal1:80, portal2:8080, portal3:8081) published on different ports. 2 - Connection from external hosts (access restricted to hosts H1, H2, H3 ) works fine on all portals. Connection from host H4 does not work for portal:8080 but works for other published portals 3 - The ISA error logs matches the traffic from external host to the portal2 on port 8080 but throws out this error (ISA error 64). I also see unsually high processing time (in the range of 1000000 ms) 4 - I am using a single listener (non https) for publishing all the portals through multiple rules. It would be really helpful if some one can throw light on this error. Regards, Karthigeyan Sankar
