Web Publishing Problem
All Forums >> [ISA Server 2000 General] >> Web Publishing >> Web Publishing Problem Page: [1]
Web Publishing Problem - 30.May2001 3:59:00 AM
tilke
ISA Server is sitting behind Linksys Cable/DSL router. Router has internal IP address of 192.168.1.1; ISA/IIS Server is 192.168.1.2. Implemented installation as per excellent Shinder tutorial. Published web site uses port 8082 on IIS. Request for web site from external client is getting to ISA as evidenced by ISA Session Monitoring. Request is also getting to IIS as evidenced by request for Index.htm in IIS W3SVC3 log. Some response is getting back to client as evidenced by 'Web Site found. Waiting for Reply', and the Linksys router outgoing log indicates a handshake of some sort. Unfortunately, client browser simply hangs and no further data is delivered to client. Request for web site works fine from within LAN. Any ideas would be greatly appreciated!
Peter Tilke
RE: Web Publishing Problem - 31.May2001 9:25:00 PM
Status: online
Hi Peter,
Interesting problem. I'm impressed that the request is making it to the external interface of the ISA Server, given that the external interface has a private IP address. I assume that you're using a 1 to 1 mapping between the router and the external interface of the ISA Server.
Try binding a public IP address to the external interface of the ISA Server and create a DNS entry for that interface and see how that works.
Tom Shinder
Get It Here
(in reply to tilke)
RE: Web Publishing Problem - 1.Jun.2001 4:09:00 AM
tilke
Tom,
Thanks so much for looking into this. I managed to identify and resolve the problem when I discovered that I was actually publishing small web pages. It turns out that there are some incompatibilities in supported TCP/IP packet sizes with DSL PPPoE that I haven't delved into completely... Any TCP/IP packet larger than 1492 bytes was getting trashed during publishing. If I explicitly set the MTU parameter on the Linksys router (now 192.168.1.2), and the exteranl interface on the ISA machine (192.168.1.1) to be 1492, then suddenly everything works! I imagine this would be a problem for many people trying to publish from behind a DSL connection with PPPoE.
Thanks again for your help and the excellent tutorial: I'm going to buy your book.
Cheers,
Peter Tilke
Hi Peter,
(in reply to tilke)
RE: Web Publishing Problem - 3.Jun.2001 2:28:00 PM
Status: online
Hi Peter,
Good to hear that you got everything working!
You must have discovered the information that helped in the Q article:
http://support.microsoft.com/support/kb/articles/Q259/7/83.ASP
Correct? Thanks for the follow up on this!
Tom Shinder
Get It Here
(in reply to tilke)
RE: Web Publishing Problem - 4.Jun.2001 2:21:00 AM
tilke
Tom,
You're absolutely correct. Using the ping test I reduced the MTU to 1464, I believe this is because ping puts a 28 byte header in, yielding 1492, but I'll follow the recommendation and reduce the MTU size to 1464.
Thanks again,
Peter
(in reply to tilke)
