Web Publishing Problems
All Forums >> [ISA 2006 Publishing] >> Web Publishing >> Web Publishing Problems Page: [1]
Web Publishing Problems - 24.May2008 11:57:33 PM
Jamsaz
Hi there,
I have problem to publish our internal web site to internet users. our network has Valid IP address,internal web server and no registerd domain. i want internet users can access to our internal web site just through Valid ip address not domain name. i created a rule in ISA Server Enterprise 2006 but nobody can access to our web site. please somebody help me.
Best Wishes
Amir Ahmadi Rad
RE: Web Publishing Problems - 26.May2008 11:21:33 PM
Jamsaz
Hi
nobody here want help me? please.
(in reply to Jamsaz)
RE: Web Publishing Problems - 27.May2008 2:10:26 AM
jarod1701
Hi Jamsaz,
I think it would be helpful if you posted some details especially about that publishing rule.
Kevin
RE: Web Publishing Problems - 29.May2008 11:30:25 AM
dranizz
Try changing the options in the "Authentication Delegation" tab of the rule. Change it to "No delegation and clients cannot authenticate directly"
(in reply to jarod1701)
RE: Web Publishing Problems - 30.May2008 11:58:18 PM
Jamsaz
Hi
My configuration is:
Action: Allow
to: Http://deny.mydomain.org
Traffic: HTTP
Listener:
           Network: External
            Port(HTTP): 80
           Authentication Method: No Authentication
           Always Authentication: No
Public Name:
           Request for the following web site: http://78.39.181.3 (Because we  haven't registerd domain)
Bridging: Web server
redirect request to port: 80
User: All Users
when i try check http://78.39.181.3 from another internet link i received error
please some one help me.
Best wishes
(in reply to dranizz)
RE: Web Publishing Problems - 3.Jun.2008 3:15:17 PM
gunjan151
what error message do you get when u access the URL.
RE: Web Publishing Problems - 6.Jun.2008 3:40:14 AM
tijlhaghebaert
if you go to the link you get this error:
I've had this error before and to me it was an authentication error. Is authentication required on the webserver? If it is, you have to change the Authentication delegation.
I think "No delegation but clients can authenticate directly" must work. Not sure of that.
Grtz
(in reply to gunjan151)
RE: Web Publishing Problems - 6.Jun.2008 6:52:23 AM
Status: online
Unless the web server is completely anonymous you will need the "no delegation and clients can authenticate directly" otherwise ISA will block the traffic at the first sign of an authentication request.
Shouldn't the "To:" field by the internal name or IP address of the server you are trying to publish?
The public name should be just the public IP address and should'nt include the http:// bit.
With the above changes, you should be good to go as you don't have to use a domain name with ISA, although it is a good idea as lots of nasties use IP address as oppsed to names
Jason Jones (MVP)
(in reply to tijlhaghebaert)
RE: Web Publishing Problems - 7.Jun.2008 11:55:06 PM
Jamsaz
Dear all
thanks for your attention. my problem is resolved.
Best Wishes
RE: Web Publishing Problems - 8.Jun.2008 1:49:20 AM
Jamsaz
Hi again
as i told my problem is resolved, but i just could publish web site. in publish virtual directories i have problem. now i can publish virtual directory in IIS to interent but when i browse files inside there i cannot download them. and i received error.
is there any differences between publish web sites and virtual directories such as http://w.x.y.z/files.
Best Wishes
