Web Publishing Rule FTP??
Web Publishing Rule FTP?? - 19.Oct.2002 5:20:00 PM
FiskerEnDK
Hi
I have a serval Web sites Published by ISA Server. and i have a Server Publishing Rule that take Port 21 for a ftp server on another server.
i have a FTP server on My Web server and my normal FTP server..
but when i trying to connect to Web server ftp that are specified by Web Publishing rule it logon to the Normal FTP server..
i want it to log on to my Webserver ftp if i ex write brian.domain.com it have to go to the ftp server at my webserver not my normal ftp server`!
how do i get it to do that?
Best Regards Thomas
RE: Web Publishing Rule FTP?? - 19.Oct.2002 9:51:00 PM
Hi FiskerEn,
You can perform protocol redirection using Web Publishing Rules.
HTH, Tom
RE: Web Publishing Rule FTP?? - 21.Oct.2002 6:47:00 PM
Hi FiskerEn,
Just redirect the HTTP request as an FTP request in the Web Publishing Rule.
HTH, Tom
RE: Web Publishing Rule FTP?? - 26.Oct.2002 6:48:00 PM
FiskerEnDK
ok i try again to tell..
i have ISA as my Gateway server.. on that i have made a Server Publishing Rule that: Port 21 -> 192.168.1.2
then i have my Web Publishing Rules these work fine..
but when i c=nnect to ex. sub1.domain.dk -> 192.168.1.3 (from my Web Publishing) on a FTP client it is not logging in to the webserver but into the server on 192.168.1.2
how can i fix that?
RE: Web Publishing Rule FTP?? - 26.Oct.2002 7:09:00 PM
Hi FiskerEn,
What is the IP address on the external interface of the ISA Server that is listening for FTP requests?
Thanks! Tom
RE: Web Publishing Rule FTP?? - 27.Oct.2002 9:14:00 PM
FiskerEnDK
my external ip is: 80.196.167.xxx
RE: Web Publishing Rule FTP?? - 28.Oct.2002 1:50:00 PM
FiskerEnDK
i know tom.. but all people a place like this is not all faiR. i newer give my IP on a public board someone maybe have clear mind to use ip fore.
but i have tried from institution and it dosent work.
maybe its becuz the port 21 is used by Server publishing?
or maybe a web listener problem?
RE: Web Publishing Rule FTP?? - 28.Oct.2002 6:56:00 PM
Hi FiskerEn,
Are you trying to use a Web Publishing Rule to publish an FTP site? If so, you need to redirect the HTTP request as an FTP request.
HTH, Tom
RE: Web Publishing Rule FTP?? - 28.Oct.2002 10:29:00 PM
FiskerEnDK
whats the mening about have a Web Publishing that have HTTP, FTP and SSL if only u can use one at one time?
and how can i then both have ex.
subdomain.domain.com to http and FTP!
RE: Web Publishing Rule FTP?? - 28.Oct.2002 11:13:00 PM
Do you have to redirect an HTTP request as FTP?
Suppose you have an internal IIS server running a HTTP and a FTP site. You want to publish both sites through ISA. If a user connects to the ISA server on port 21, redirect to the IIS server on port 21. If a user connects to the ISA server on port 80, redierct to the IIS server on port 80.
Shouldn't this be possible? If you're forced to redirect a HTTP request, then you're out of luck. I'm in a similiar situation as FiskerEnDK. I want to redirect a user based on teh port he connects.
RE: Web Publishing Rule FTP?? - 29.Oct.2002 9:19:00 PM
Hi FiskerEn,
You need to create two rules, if you want to publish HTTP and FTP on the same internal network server. On the second rule, redirect HTTP as FTP.
HTH, Tom
RE: Web Publishing Rule FTP?? - 29.Oct.2002 10:48:00 PM
FiskerEnDK
ok kan jeg tell me how then?
FiskerEnDK
can u
RE: Web Publishing Rule FTP?? - 30.Oct.2002 6:07:00 PM
FiskerEnDK
the stream dosent work??
RE: Web Publishing Rule FTP?? - 1.Nov.2002 7:19:00 PM
Hi FiskerEn,
I'll do an article on this topic next week.
Thanks! Tom
RE: Web Publishing Rule FTP?? - 3.Nov.2002 6:25:00 PM
FiskerEnDK
U are the man of the day.. thanks man..!
RE: Web Publishing Rule FTP?? - 3.Nov.2002 6:26:00 PM
Hi FiskerEn,
Thanks! I hope the article helped you.
