Web Publishing did not work when firewall went live.
All Forums >> [ISA 2006 Publishing] >> Web Publishing >> Web Publishing did not work when firewall went live. Page: [1]
Web Publishing did not work when firewall went live. - 29.Jan.2007 2:02:27 PM
darrylb
Hello all,
I have recently completely configured an ISA Firewall 22006 and ran into an issue. With all the publishing rules I created, all worked but one.
When the firwall was put in place, none of our websites could be accessed. We manage over 20 domains of sites. We dont really care to use any of the ISA filteringt options for web. We just more or less want a single external ip to foward to an internal ip.
What settings must I put in place to get this configured? I dont want to need to add the appropriate domain everyime we host another domain, into the ISA server (nor does my boss).
Thanks.
RE: Web Publishing did not work when firewall went live. - 30.Jan.2007 10:53:43 AM
Hi Darry,
What's the point of using the ISA Firewall?
Sounds like you're trying to gut all the security out -- if you don't want a secure configuration, use a PIX or ASA.
(in reply to darrylb)
RE: Web Publishing did not work when firewall went live. - 30.Jan.2007 10:58:21 AM
darrylb
Your making the assumption that because we dont want to use a single part of the ISA that the whole ISA server is not of any use... There is lots of stuff we are using on the ISA Firewall that we cant do on lower end firewalls. Why is it you cant just give me an answer, we have plenty of reasons to use ISA Firewall, we just dont want to use the Web Publishing part.
RE: Web Publishing did not work when firewall went live. - 31.Jan.2007 12:08:19 PM
In that case you can create Server Publishing Rules for the Web sites. Just make sure there is no socket contention with any Web listeners.
RE: Web Publishing did not work when firewall went live. - 31.Jan.2007 1:15:09 PM
darrylb
Okay, so just publish the port using the Server Publishing... Good idea.
Thanks a lot Tscinder--as soon as we are finished testing out the hardware thoroughly, we will be reimplementing the ISA Firewall with that change.
RE: Web Publishing did not work when firewall went live. - 1.Feb.2007 11:53:13 AM
Hi Darryl,
You bet! Hope things get to working right.
RE: Web Publishing did not work when firewall went live. - 1.Feb.2007 11:59:53 AM
darrylb
As you can imagine, so do I..
Still running hardware tests...but the memory has checked out okay in 18hrs of non-stop memory tests :)
