Web Publishing problem after switching from ISA2000 to ISA2004
All Forums >> [ISA Server 2004 General ] >> Web Publishing >> Web Publishing problem after switching from ISA2000 to ISA2004 Page: [1]
Web Publishing problem after switching from ISA2000 to ... - 25.May2005 3:52:00 PM
mdbnc2005
Hello,
I have ran into a dilema after switching to ISA2004 from ISA2000. Here is a detailed description of the problem:
In ISA2000 you could have a Web Publishing rule that contained wildcards in the path like this example:
Rule 1 has the path /msadc/msadcs.dll/pathA*
Rule 2 has the path /msadc/msadcs.dll/pathB*
(note that there is no / before the asterix)
These two rules would work fine with ISA2000, the path is generated by an application that appends several variables after the * based on the method requested in msadcs.dll.
In ISA2004 however, it appears that it does not allow a wildcard in a path without a / before it, which is the root of my problem.
Is there any way possible around this problem, or am I at a loss with this "improvement" in ISA2004?
RE: Web Publishing problem after switching from ISA2000... - 27.May2005 9:00:00 AM
Hi Compguy,
Works the same way, you just need to include the /* with the new ISA firewall.
(in reply to mdbnc2005)
RE: Web Publishing problem after switching from ISA2000... - 27.May2005 10:31:00 AM
mdbnc2005
Ok I will try it, though it does seem strange. Just to clarify a bit this is why it brought some confusion:
pathA can be almost anything, for example:
pathA.method1.method4045
or
pathA.method2.method400
same thing applies to pathB
