Web access logging to MySQL problem
All Forums >> [ISA 2006 Firewall] >> Logging and Reporting >> Web access logging to MySQL problem Page: [1]
Web access logging to MySQL problem - 30.Jul.2008 10:35:01 PM
krazibone
Good afternoon/evening
I've been following the instructions from this article http://www.isaserver.org/tutorials/mysql.html but i'm currently stuck on the last step.
Since these steps below are for ISA 2000 can this be interpreted for ISA 2006 ? If so  can some body guide me to the right direction on how to do this...
Open the ISA mmc, expand Monitoring and Configuration, and select Logs
Double-click on ISA Server Web Proxy Service
Select Database.
In the ODBC field type in isa_access
Type WebProxyLog in the Tables field (case sensitive).
Make sure the "Use this account field" is blank.
Repeat previous steps for the packetfilter log, and the firewall log.
Table names are PacketFilterLog and FirewallLog
< Message edited by krazibone -- 30.Jul.2008 10:37:24 PM >
RE: Web access logging to MySQL problem - 31.Jul.2008 9:30:44 AM
paulo.oliveira
check this articles: http://support.microsoft.com/kb/838710
http://www.isaserver.org/tutorials/Firewall-Logging-Microsoft-SQL-database.html
Paulo Oliveira.
(in reply to krazibone)
RE: Web access logging to MySQL problem - 31.Jul.2008 9:24:59 PM
krazibone
Hi thank you for your response but those links are more setting up ISA 2006 with MS SQL
With MySQL the article uses MS access database as the middle application to transfer data to MYSQL. From what i can see from ISA 2000 you were able to inject data into a MS access database, can this be done with ISA 2006 if so how? because at the moment i can't find the option on how to do this.
(in reply to paulo.oliveira)
