Web chaining loop
All Forums >> [ISA Server 2004 Firewall] >> Access Policies >> Web chaining loop Page: [1]
Web chaining loop - 25.Sep.2004 11:29:00 PM
dan5218
Hello all,
I have recently moved from ISA 2000 to ISA 2004, and almost everything is working great. I have DHCP, web access, server publishing, SSL, the whole nine yards, all working great. I have only one problem now. Here is my cofiguration:
I have a router with my public IP address. My ISA server has two NICs with IPs 192.168.0.1 (internal) and 192.168.1.2 (external to router). My servers and clients are on the same internal network. My DNS resolves my domains with the external IP of the router (as it should) and everything inbound works fine; however, when I try to access these domains with my local clients, they connect to the router.
What I need is for ISA to redirect internal requests for my external IP to my web server. What I did was create a web chaining rule using a URL set with my domains listed in it and set it to redirect requests to a hosted site. What happens now when I try to connect to these sites is that the browser just sits there and the progress bar flickers as if it is loading over and over again. I had this working on ISA 2000, what am I doing wrong?
Thanks in advance!
RE: Web chaining loop - 26.Sep.2004 5:47:00 AM
dan5218
Okay, a little update. The chaining finally started working for me but it's not passing the host header information. So I've decided to go back to the web publishing rule and see if I'm missing something. I added my internal IP addresses to the listener and put "Internal" on the "From" tab. Now it's back to just dumping me on my router instead of forwarding me to the server.
(in reply to dan5218)
