Web chaining really slow
Web chaining really slow - 20.Aug.2004 4:24:00 PM
xdu
Hi all,
I'm using ISA 2004 on my LAN, web-chained to my proxy/firewall. I'm also using one firewall rule filtering users based on Active Directory group.
This configuration works, but is WAY slower than a direct connection to my FW/proxy. ISA log shows that after authentication, it waits about 30 seconds for the other proxy's answer, and that is for each request it makes.
Before I fire Ethereal to make packet capture, has anyone got a clue on what may be going on ?
Thanks in advance
Xavier
RE: Web chaining really slow - 22.Aug.2004 3:18:00 AM
Status: online
Hi Xavier,
When using two ISA firewalls in a Web chaining configuration, you must make sure that the downstream ISA firewall can resolve the name of the destination FQDN. Is the downstream ISA firewall cannot do this, then disable name resolution on the downstream ISA firewall. There are some instructions on how to do this on the MS.com "coders corner" ISA firewall site.
HTH, Tom
RE: Web chaining really slow - 23.Aug.2004 9:06:00 AM
xdu
Thanks a lot ! That was it, indeed : DNS resolution. Microsoft has a knowledge base article about this issue (Q292018), but it concerns only ISA 2000.
I'm still looking for the way to tell a downstream 2004 server not to use DNS resolution. I'm quite sure it's a feature included in ISA 2004, as it was a fix for 2000.
If anyone knows...
Thanks again anyway.
RE: Web chaining really slow - 23.Aug.2004 9:37:00 AM
xdu
I've got it, at last ! The script to disable DNS on downstream ISA server is here : http://www.microsoft.com/technet/prodtechnol/isa/2004/plan/disablenameresolution.mspx
It applies to ISA 2004. Strange enough, it's not just a registry key that controls this behaviour, you have to script it.
Thank you Tom for your fast and precise answer.
RE: Web chaining really slow - 24.Aug.2004 2:41:00 AM
Status: online
Hi Xdu,
