Web listener will not allow Cert to be attached
All Forums >> [ISA Server 2004 General ] >> Exchange Publishing >> Web listener will not allow Cert to be attached Page: [1]
Web listener will not allow Cert to be attached - 24.Oct.2007 12:14:43 AM
jestronix
When I create a new web listener I cannot use a ssl cert. I simply will not allow me to select from the select button. "To select a certificate you must at least install one identical certificate on each member server"
Trouble is I have an array consisting of only one server, I have added the cert onto this server.
Any ideas how to get around this?
RE: Web listener will not allow Cert to be attached - 24.Oct.2007 9:50:13 AM
Rotorblade
When you created the new web listener, did you also define and add an additional IP to the External NIC to bind the new listener to?
RB
(in reply to jestronix)
RE: Web listener will not allow Cert to be attached - 24.Oct.2007 9:56:41 AM
Rotorblade
Also...
Are you importing the Cert. correctly to the ISA server?
http://www.microsoft.com/technet/isa/2004/plan/tscerts.mspx
RB
(in reply to Rotorblade)
RE: Web listener will not allow Cert to be attached - 24.Oct.2007 10:11:54 AM
Rotorblade
One more thing..
Are you trying to setup certificate auth. on the bridging tab?
RB
