Web mon 3.1 deployment array issues
All Forums >> [ISA Server 2004 Misc.] >> 3rd Party Add-ons >> Web mon 3.1 deployment array issues Page: [1]
Web mon 3.1 deployment array issues - 5.Mar.2006 5:19:03 AM
G420
when install web monitor 3.1 on second member array this message appear on first member ang gfi dont work on this server "webfilter was not registered on this server GFI WbMonitor3filter is not installed, install the filter and then restart firewall"
When Integrate NLB is enable on ISA 2004 over Windows 2003 SE SP1 Microsoft recommend activate web proxy on INTRA ARRAY NETWORK (rule dedicate to netwoks cards for tihs purpose) well WM3 generate errors like "Upstream chaining credentials intra-array communication"
what happen??????????????
RE: Web mon 3.1 deployment array issues - 5.Mar.2006 11:43:25 AM
hi,
have you checked the manual?
Use the procedure explained in the WebMonitor manual (in the section "Deploying and using GFI WebMonitor on multiple ISA Servers or ISA Server arrays")
(in reply to G420)
RE: Web mon 3.1 deployment array issues - 6.Mar.2006 2:10:35 AM
G420
Thnaks for your answer, off course i reed gfi manual, the problem appears only when you created INTRA NETWORK RULE and activate proxy listener for NLB, the microsoft information about implementation is very inconsistent. MOM knowledge base is to poor.
anyway......
(in reply to G420)
RE: Web mon 3.1 deployment array issues - 20.Mar.2006 12:49:11 AM
G420
Well the problem is CARP
Web monitor 3.1 DONT SUPPORT CARP, only work in SOME CASES
(in reply to G420)
RE: Web mon 3.1 deployment array issues - 22.Mar.2006 1:40:25 PM
yah i heard this also on the GFI product forum from one of their Tech Support.
(in reply to G420)
