Web publish problem
All Forums >> [ISA Server 2004 General ] >> Web Publishing >> Web publish problem Page: [1]
Web publish problem - 18.May2004 1:15:00 PM
Kapo
After i install the isa server 2004 in my firewall server , i try access from outside to my web sites and I get the follow error:
"403 Forbidden - The server denies the specified Uniform Resource Locator (URL). Contact the server administrator. (12202)
Internet Security and Acceleration Server"
After install isa server, I create in police rules two rules to publish two different domains (www.a.com and www.b.com) from my internal web server( In IIS they have ports different).
Before these install this scenario is working correctly with isa server 2000.I don’t now what mistake I make. I publish too the exchange webmail and is working perfectly.
RE: Web publish problem - 18.May2004 9:21:00 PM
Hi Kapo,
What are the details of your Web Publishing Rules? It sounds like the public name isn't right on these rules.
HTH<
(in reply to Kapo)
RE: Web publish problem - 19.May2004 5:41:00 PM
Kapo
I discover after same tests the problem is in listeners.
I build two listeners for the publishing sites û one for my web server publish (port 80) (without authorization) and other for my webmail with owa autorization and domain integration.
So,I resolve my sites problem after i stop the rule webmail publish.
What I must do to have two listeners in same port with different authorizations?
(in reply to Kapo)
RE: Web publish problem - 23.May2004 5:14:00 PM
Hi Kapo,
If you want to have one listener require authentication and the other not require authentication, you need to create two listeners. Each listener can be on the same IP address using different ports, or each listener can use a different IP address.
(in reply to Kapo)
