Web publishing
All Forums >> [ISA Server 2000 General] >> Installation >> Web publishing Page: [1]
Web publishing - 23.Feb.2001 7:51:00 PM
clynn
I am finding publishing my web server very confusing. My inexperience doesn't help. I have ISA installed, clients are connecting as secureNAT, as well as my server. The server is the main box in my office. It's running W2K Adv Server, DNS, DHCP, Active Directory, Exchange 2000, IIS with 2 Websites.
Exchange 2000 is running proerly now (sigh of relief). So I know the secureNAT is operating properly.
Currently:
My ISP translates www.domain.com to my firewall x.x.x.42. This firewall is just a linux box forwarding ports. x.x.x.42/80 ---> 10.10.10.2/80 (ip of web server). I have connected ISA (x.x.x.44)on the same hub as linux which in turn is connected to my router. If the web publishing was set up correctly, I should be able to get to my site via http://x.x.x.44/80, right?
This is what I've done so far:
Destination set: www.domain.com-->10.10.10.2
Do I need a path?
Published Server: x.x.x.44 --> 10.10.10.2 HTTPS Server (I know this isn't right)
Web publishing rules: ?
Could someone help me out here.
Thanks Chris
RE: Web publishing - 24.Feb.2001 9:18:00 AM
Status: online
Hi Chris,
First, you should consider making the ISA Server your firewall, since that's what its made to do
You should have "www.domain.com" resolve to the external IP address of the ISA Server. By default, the external listener (Inbound Web Requests Listener)will default to port 80, but you can change that if you like.
Next, create a destination set for "www.domain.com". That is exactly what you should enter when you create the destination set. Click the option button for "destination" and in the text box type "www.domain.com".
When you publish the web site, use this destination set.
Tom Shinder
(in reply to clynn)
RE: Web publishing - 24.Feb.2001 7:51:00 PM
clynn
I am trying this today. ISA will be my firewall instead of the linux box. I'm sure I'll be back with questions.
Thanks Tom,
Chris
(in reply to clynn)
RE: Web publishing - 25.Feb.2001 8:57:00 PM
Status: online
Hi Chris,
Let us know how it worked out!
Tom Shinder
(in reply to clynn)
RE: Web publishing - 26.Feb.2001 6:25:00 PM
clynn
Here's where I'm at:
ISA Ext address: x.x.x.42
ISA Int address: i.i.i.1
Web Srv sddress: i.i.i.2
ISP's DNS resolves www.domain.com to x.x.x.42
Created Destination set: www.domain.com to destination www.domain.com
(also tried dest = i.i.i.2)
Created web publishing rule:
to got to destination www.domain.com
I checked my internal DNS. Clients can resolve www.domain.com to the local web server. But only when they auto detect settings in IE, not when configured as SecureNAT clients.
SecureNAT gets the following error on internal client:
10061 - Connection refused
Internet Security and Acceleration Server
*Background:
The server you are trying to access has refused the connection with the gateway. This usually results from trying to a service that is inactive on the server.
I was optomistic on this attempt, because this seems so easy to set up. But I still can't get anywhere.
Any Ideas?
Chris
Another thing I was concerned with was the web access for Exchange 2000. When users log on, they use their browsers to go to www.domain.com/exchange. This web access is a folder within the default web site on IIS. Wondering if any one had to use any special settings?
[This message has been edited by clynn (edited 26 February 2001).]
(in reply to clynn)
RE: Web publishing - 26.Feb.2001 9:20:00 PM
clynn
In trying to track down what is wrong, I tried to telnet to www.domain.com 80. No responce. Does this mean I don't have the proper listeners in place. If so how do I correct this?
Nevermind, listener was not configure. I knew it was something stupid. For anyone reading this with a similar problem, the listener can be configured by right clicking the server in ISA Manager. Go to properties, click the tab, "incoming web requests"
(in reply to clynn)
RE: Web publishing - 27.Feb.2001 6:43:00 PM
Status: online
Hi Chris,
Ha! Good to see you got it figured out. BTW, I wrote an article about some of the things you should do prior to publishing a web site. Check it out at:
It might be helpful in making sure all the "pre flight" is done before doing the actual publishing.
Tom Shinder
(in reply to clynn)
