Web publishing
All Forums >> [ISA Server 2000 General] >> Server Publishing >> Web publishing Page: [1]
Web publishing - 24.Apr.2003 1:52:00 PM
Alex.U
I have ISA behind a router. Beside the gateway for my subnet, the router can translate some public IP to some private range IP (that IP assigned for external NIC of ISA server), if i ping that external router's IP from Internet i see incoming request and responce at external NIC of ISA. But if i publish server from my subnet i resieve "Page can't be displayed". What can i do.
Thank for any answer.
RE: Web publishing - 24.Apr.2003 7:49:00 PM
fogbank
Make sure your router is set to forward HTTP to ISA. If ISA is configured to publish a web server, and it is behind a router that uses NAT (sounds like your setup) then you need to configure the router to forward HTTP (port 80) requests to the ISA Server's external interface. If your router uses NAT and DHCP, make a DHCP reservation for the ISA Server's external interface so it will always get the same address from your router. Then forward port 80 to that IP address.
(in reply to Alex.U)
