Web publishing - has to be done in firewall mode in ISA 2004 SE?
Web publishing - has to be done in firewall mode in ISA... - 12.Oct.2004 7:26:00 PM
ristic
In ISA 2000 SE when installing you get prompted do you want to install in firewall mode, cashing only or integrated - in ISA 2004 SE you never get that choice, its firewall mode only? Even when I have only one NIC and all I wan't to do is web publishing (I use Cisco PIX firwalls so no need for ISA in firewall mode) - in ISA 2004 I have to use it in firewall mode? Or am I mission something...?
RE: Web publishing - has to be done in firewall mode in... - 12.Oct.2004 7:57:00 PM
Hi Ristic,
I'd SERIOUSLY reconsider your asssement regarding not needing the ISA firewall as a firewall. The PIX is a simple packet filter. Personally, I would NEVER trust my own assests and those I in charge of protecting to a packet filter like PIX.
You can use the PIX packet filter to offload some processing off the ISA firewall, but don't fool yourself that the PIX is providing real firewall protection.
HTH, Tom [ October 12, 2004, 07:57 PM: Message edited by: tshinder ]
RE: Web publishing - has to be done in firewall mode in... - 22.Oct.2004 12:04:00 PM
Jeroen_317
ISA2004 always has the firewall enabled because *grmblz* they implemented the web proxy into the firewall service so it has the be running. I heard it was required for enhancing speed...
If anyone know of a configuration or registry hack which disables the firewalling and only enables the web proxying, I would be VERY thankful.
Jeroen.
