Web publishing in DMZ with one NIC card
Web publishing in DMZ with one NIC card - 21.Aug.2005 9:19:00 PM
yaott
We have a firewall, a DMZ, and internal network. ISA2K4 is in DMZ with one NIC card. We want to publish securely an internal web site using ISA using SSL bridging. The web publishing rule accepts any HTTPS traffic from External to www.xxx.com (a local host entry on ISA resolves this address to web server internal IP address). Web site public name is also www.xxx.com. The web listener accepts HTTPS request from all networks.
This configure does not appear to be working. ISA log shows connection from External to local host is established on port 443, but immediately terminated.
Why? Does one NIC card support web publishing?
RE: Web publishing in DMZ with one NIC card - 22.Aug.2005 9:16:00 AM
Hi Tony,
The ISA firewall is a firewall. Sure, it has a Web proxy *filter* and a Firewall client Winsock proxy component, but you can turn both of those off easily. You CAN'T turn off the ISA firewall's firewall components. That's because the ISA firewall is a firewall first, second and last.
Yes, you can Web publish with a unihomed ISA firewall, but it breaks a lot of the ISA firewall's firewall model. Get a second NIC in that ISA firewall and all the standard procedures will work fine.
HTH, Tom
RE: Web publishing in DMZ with one NIC card - 22.Aug.2005 4:43:00 PM
yaott
Thanks Tom,
I did not make myself clear enough. We have a PIX firewall, a DMZ where the ISA2K4 box sits, and internal network.
Do I have to have another NIC installed on ISA box to make this work?
Tony
