Web publishing not working on the ISA 2006
All Forums >> [ISA 2006 Publishing] >> Web Publishing >> Web publishing not working on the ISA 2006 Page: [1]
Web publishing not working on the ISA 2006 - 18.Dec.2006 5:04:51 AM
activesoft
Hi All I have a web publishing problem on the ISA 2006. I only work with ISA 2000, so not experienced on the ISA 2004/2006. Here is my test lab configuration.
ISA Server:
Ethernet adapter Perimeter:
Connection-specific DNS Suffix  . :
Description . . . . . . . . . . . : Compaq NC3121 Fast Ethernet NIC #2
Physical Address. . . . . . . . . : 00-08-C7-D9-BE-B9
IP Address. . . . . . . . . . . . : 192.168.20.1
Ethernet adapter ASFT External:
Physical Address. . . . . . . . . : 00-50-8B-61-75-B6
IP Address. . . . . . . . . . . . : 192.168.0.20
Default Gateway . . . . . . . . . : 192.168.0.1
DNS Servers . . . . . . . . . . . : 210.55.12.1
                                     210.55.12.2
Ethernet adapter Internal:
Description . . . . . . . . . . . : 3Com EtherLink XL 10/100 PCI For Complete
PC Management NIC (3C905C-TX)
Physical Address. . . . . . . . . : 00-01-03-45-01-A6
IP Address. . . . . . . . . . . . : 192.168.10.1
I have entered "testsite" on the ISA server local hosts file, [192.168.20.20 testsite]
WEB server, it is on the perimeter network:
IP Address. . . . . . . . . . . . : 192.168.20.20
Default Gateway . . . . . . . . . : 192.168.20.1
I setup a web site http://testsite on this web server (I have entered "testsite" on the web server local hosts file[192.168.20.20 testsite])
PC, it is on the internal network:
IP Address. . . . . . . . . . . . : 192.168.10.10
Default Gateway . . . . . . . . . : 192.168.10.1
I have entered "testsite" on the pc local hosts file, [192.168.20.20 testsite]
I setup:
1) ISA server networks:
internal : 192.168.10.1 - 192.168.10.255
primeter : 192.168.20.1 - 192.168.20.255
asft external:  : 192.168.0.1 - 192.168.0.255
2) 3-Leg Perimeter network template
3) set up a network rule to route from source network [internal,primeter,asft external] to [internal,primeter,asft external]
4) set up a firewal policy to allow ping from [internal,primeter,asft external] to [internal,primeter,asft external]
5) Set up web listener called "ASFt listener" with following properties:
Networks = [internal,primeter,asft external]
client connection type, enable http connections on port 80
authentication : no authentication
6) set up a web publishing rule:
Action : allow
To: published site = testsite, computer name or IP address = 192.168.20.20, forward the original host header, Requests appear to come from the original client
Listerenr: "ASFt listener"
Public Name: this rule applies to all the rules
I thought I setup every thing right but some how the web publishing rule not working.
I can ping from [pc,webserver,isaserver] to  [pc,webserver,isaserver], all working fine.
When I look at the monitoring log, the ISA server is Denied the connection by Default rule. It is not even processing the web publish rule, which is the first rule on the list.
I would appreciate if you guys tell me what I am doing wrong. I am very confused about the web publishing rule.
Thank you in advance.
Raj
< Message edited by activesoft -- 18.Dec.2006 5:06:42 AM >
RE: Web publishing not working on the ISA 2006 - 19.Dec.2006 10:34:17 AM
Hi Raj,
Check out the book link in my signature so that you can learn about the ISA 2004 Firewall, which works just about the same as the 2006 ISA Firewall.
(in reply to activesoft)
RE: Web publishing not working on the ISA 2006 - 20.Dec.2006 1:00:51 AM
activesoft
Thanks Tom.
I am going to buy that book but it is going to take another couple of week cos ordering from Amazon.
At the mean time I fixed the issue, now every thing working fine.
Basically I made a silly mistake, host file entries were wrong.
Thanks you all.
Raj
< Message edited by activesoft -- 20.Dec.2006 1:03:19 AM >
RE: Web publishing not working on the ISA 2006 - 20.Dec.2006 10:21:50 AM
Hi Raj,
