Web publishing rule processing
All Forums >> [ISA 2006 Publishing] >> Web Publishing >> Web publishing rule processing Page: [1]
Web publishing rule processing - 20.Mar.2007 1:35:17 PM
55west
How can I publish a HTTPS site that first authenticates by IP and if the IP is not allowed then to authenticate via HTML form? I can achieve this by using two different listeners but I would really like to use one (or at least one IP address that clients connect to).
We had this setup on our ISA2000 box. Any suggestions?
RE: Web publishing rule processing - 20.Mar.2007 7:00:35 PM
mylo
I'm not quite sure I follow you 100% but....
..publish a HTTPS site that first authenticates by IP.. you mean limit access thru ISA to specific address(es)/clients? you could alway use client certs and then fallback to a secondary authentication (not forms tho)
Mylo
(in reply to 55west)
RE: Web publishing rule processing - 21.Mar.2007 12:44:18 PM
55west
We are using the ISA server in a reverse proxy scenario. We would like to authenticate connecting clients via IP first then authenticate by username/password if their IP address is not allowed.
(in reply to mylo)
RE: Web publishing rule processing - 22.Mar.2007 9:50:48 AM
mylo
Hmm.. you're going to have problems because strictly speaking identification of an IP address does not qualify as a form of authentication... you can apply a rule to a given source but this is not what you're after... the only conditional access that I can think that can apply here with a web listener is where you allocate a client certificate to a given client (which isn't exactly precise) and then degrade authentication to something like basic authentication when the client fails to or doesn't support this form of authentication. Of course this doesn't meet your HTML form requirement.
Can you elaborate a bit more on the how and the why?
Mylo
RE: Web publishing rule processing - 22.Mar.2007 12:17:05 PM
55west
I don't mean we are "authenticating ip" but rather certain IP ranges are allowed through. Our application has it's own login screen so customers with allowed IP's are still required to login. However, we have several customers that also work from home. Since maintaining their home IP's is diffuclt and unmanageable we would like to pre authenticate them with a forms-based screen instead.
Now the trick is how can we achieve both but with only one external IP (listener)?
(in reply to mylo)
