Web publishing rules with Java applet contents
Web publishing rules with Java applet contents - 12.Jul.2005 5:52:00 AM
cybernard
I have published web server using secure web server publishing rules. What I¦ve done is.. defined listener, attached SSL certificate to listener, next, click, finished. I used host headers for identifing web server which uses https, done, everything works well, I have access through all site fine. Particular web server has implementation of Java forms by our developers. Oooph, developers, developers, developers :-) Since everything worked out, I wanted to include authentication on web server using listener¦s domain log on authentication, which actually works well, but when Java applets gets loaded through web, it loads with some errors. I have asked Java applet designers-coders beacause they provide us official support, they said that no http headers should be modified. Particulary sections KEEP-ALIVE and PRAGMA ?? O.K. I can understand for KEEP-ALIVE, but what is PRAGMA?? Anyway, I¦ve tried some settings on web listener options, preferences, RSA SecurID. None of these options works fine in combination if I am using domain authentication on listener. Does anybody knows how to exclude any http filtering on custom defined listeners, through registry or else ? If it is possible, am I degrading application filtering security on ISA server. "Bit" of text :-) isn¦t it. Anyway thanks a lot guys.
RE: Web publishing rules with Java applet contents - 12.Jul.2005 10:48:00 PM
Status: online
Hi Nard,
Have you made any changes to the HTTP Security Filter?
What errors do you see in the ISA firewall's log files related to these connections?
ISA shouldn't change the pragma header, unless your Web chaining rule is configured to do it.
HTH, Tom
RE: Web publishing rules with Java applet contents - 15.Jul.2005 2:49:00 AM
cybernard
Oh, I¦ve forgot to mention... There are no webchaining rules, there are no errors in ISA firewall logs.I guess ISA doesn¦t logs any errors instead assumes that everything is O.K. :-)
