Webserver Help
Webserver Help - 31.Jan.2007 12:27:37 PM
jbarrett@slrsd.org
Hi Everyone, The issus I am having, and I'm not sure if it is ISA Related. We have an AD Domain ****.prvt on the inside and a *****.org for of external website. Our Web server is located behind our ISA Server. I have Web Server publishing rule and everything is working fine The web site has an internal address of 10.x.x.x The problem I am having is whenever someone access the website they go out to internet and back in to internal network to access website. I would like to cut down on my bandwidth by making internal users go directly to website on the inside. Then have them go out to internet then back in to internal network. Thanks Jackie
RE: Webserver Help - 2.Feb.2007 2:59:53 PM
jbarrett@slrsd.org
Tom, Did the trick. I also had to create a rule to allow access to Web Server IP Address. Everything seems to be working. Again thatnks for the help Jackie
RE: Webserver Help - 3.Feb.2007 6:09:03 PM
jbarrett@slrsd.org
Tom, Came up with another problem now. When I try to access OWA from internal network I am getting Error Code 10061: Connection refused Background: The server you are attempting to access has refused the connection with the gateway. This usually results from trying to connect to a service that is inactive on the server. Date: 2/3/2007 10:59:51 PM Server: FRANKLIN.XXXX.PRVT Source: Remote server The address for OWA is mail.xxxx.org In my DNS I have an entry for Host record that point mail.xxxx.org to my public address. I know there is a routing issue and\or access policy issue but not sure what it is. OWA works fine outside of internal Network. Thanks Jackie
RE: Webserver Help - 4.Feb.2007 11:47:37 AM
Status: online
Hi Jackie, Enable the Web listener on the internal interface as well, and then configure the split DNS to resolve the name for internal users to the internal interface address. HTH, Tom
RE: Webserver Help - 4.Feb.2007 1:15:07 PM
jbarrett@slrsd.org
Tom, I think I have something messed up. Here is my setup DNS server One zone for NETWORK.PRVT, this is for internal Network, I created another zone for Network.ORG in this zone I created host record for www.network.org that points to my website with an address of 10..x.x.x this is working fine now when users go to website they stay on internal network as was the original problem. I also created a host record for mail.network.org with an address of 216.x.x.x. Before I setup zone for NETWORK.ORG everything worked fine. I have an weblistener that that uses external network I have enabled http port 80 and ssl port 443. Certificate is SERVER.NETWORK.PRVT. Authentication is OWA Form based. I am using ssl so I could enable "Change Password" in OWA. Works fine. My NIC on ISA SERVERS are as follow Internal NIC IP 10.2.5.2 SM 255.255.255.0 DG 10.2.0.253 DNS 10.2.5.3 10.2.5.5 External NIC IP 10.2.0.253 SM 255.255.255.0 DG 10.2.0.254 NO DNS entries 10.2.0.254 is the internal address of our router, and the outside address of router is 216.x.x.x which is the IP address of mail.network.org Tom any help would be greatly appriciated. I hope I've given you enough info. Thanks Jackie
RE: Webserver Help - 6.Feb.2007 12:01:30 PM
Status: online
Hi Jackie, You still need to create split DNS entries so that internal users use the internal interface to reach the site and external users use the external interface to reach the site. HTH, Tom
RE: Webserver Help - 8.Feb.2007 12:27:44 PM
jbarrett@slrsd.org
Tom, I forgot to tell you I have Web Proxy enabled using port 8080. If I shut off the Web Proxy, I get OWA to work fine, but when I turn it back on I still get the error. I did some logging and it looks like it is the Default rule that is blocking it. The rule that is setup when you first install ISA. Any Ideas. Again Tom thanks for the help Jackie
RE: Webserver Help - 13.Feb.2007 3:50:34 PM
Status: online
Hi Jackie, The Web proxy setting shouldn't matter, because the split DNS and Direct Access will forward the connection to the internal Web listener, which is listening on TCP 443. HTH, Tom
