Weird problem with OWA FBA session timeout
Weird problem with OWA FBA session timeout - 26.Oct.2004 4:14:00 PM
Pretty much standard OWA publishing setup with ISA2k4. FBA auth, SSL bridging, 2 NIC ISA, ISA member of domain, FBA is disabled on FE.
All seems to work pretty much 100% until user sessions timeout. If users leave OWA open for more than the public computer timeout (22 mins I think) and then click on any item within OWA screen, they are told their session is timed out and they are prompted to relogon (as normal). However, once they enter their credentials they recieve a "Unknown Request. The request could not be resolved by the server." in a white window. If they close the browser and relogin, all works fine.
Has anyone else seen this???
RE: Weird problem with OWA FBA session timeout - 27.Oct.2004 3:44:00 PM
Hi Jason,
Interesting! I'll have to test this and see what happens.
Thanks! Tom
RE: Weird problem with OWA FBA session timeout - 10.Nov.2004 2:29:00 PM
Dunch
Lisning too, having the same problem.
RE: Weird problem with OWA FBA session timeout - 11.Nov.2004 12:33:00 AM
Dunch
No, iŠll think that i have tryed eany thing.
RE: Weird problem with OWA FBA session timeout - 22.Nov.2004 10:43:00 PM
Xirito
Hi Jason, i have the same problem, only i have this on my windows mobile phone. also what do you see in your monitoring logs? Original Client IP Client Agent Authenticated Client Service Server Name Referring Server Destination Host Name Transport MIME Type Object Source Source Proxy Destination Proxy Bidirectional Client Host Name Filter Information Network Interface Raw IP Header Raw Payload Source Port Processing Time Bytes Sent Bytes Received Result Code HTTP Status Code Cache Information Error Information Log Record Type Log Time Destination IP Destination Port Protocol Action Rule Client IP Client Username URL Source Network Destination Network HTTP Method 0.0.0.0 Mozilla/4.0 (compatible; MSIE 4.01; Windows CE; Smartphone; 176x220; SPV C500; OpVer 4.1.3.0) No Reverse Proxy owa.mydomain.nl TCP - - - - - - 0 2812 624 709 12210 An Internet Server API (ISAPI) filter has finished handling the request. Contact your system administrator. 0x0 0x200 Web Proxy Filter 22-11-2004 22:41:19 212.x.x.x. 443 https Failed Connection Attempt 194.x.x.x. anonymous http://owa.mydomain.nl/CookieAuth.dll?Logon POST
I think this API filter might mess things up....
