What does WSAEADDRNOTAVAIL mean??
All Forums >> [ISA 2006 Firewall] >> Access Policies >> What does WSAEADDRNOTAVAIL mean?? Page: [1]
What does WSAEADDRNOTAVAIL mean?? - 2.Sep.2007 11:09:19 AM
tpduffo1
Hi Guys,
I have a problem that I have never seen in my 4 years working with ISA. Here is the situation ...
* A server as a Secure NAT client behind an ISA2006 FW
* Server has 1 Nic IP config as follows
192.168.x.242 / 24
Gateway = 192.168.x.8
*ISA Server Internal NIC has lots of IP addresses, address for this client is ;
192.168.x.8 / 24 and no default gateway
I have an Allow All Outbound Traffic access rule from the Server IP (192.168.x.242) to External
Whenever I start attempt to browse to any website from the protected server I never get anything and when I check the ISA logs there are always several entries as follows ;
1st showing ERROR_SUCCESS
2nd showing 0x80072741 WSAEADDRNOTAVAIL
Has anyone any idea what this error means??
FYI all other traffic using other protocols seems fine. WEIRD!!!!
PLease HELP!!!!!
Tim
RE: What does WSAEADDRNOTAVAIL mean?? - 2.Sep.2007 12:05:40 PM
is this a single NIC ISA ?
Windows Expert - IT Pro MVP
(in reply to tpduffo1)
RE: What does WSAEADDRNOTAVAIL mean?? - 2.Sep.2007 2:26:58 PM
tpduffo1
Hi Rarek,
No it isn't,  there is a second NIC for the external interface.
RGDS
Tim
(in reply to elmajdal)
RE: What does WSAEADDRNOTAVAIL mean?? - 2.Sep.2007 3:08:16 PM
Check this if it helps : http://support.microsoft.com/default.aspx?scid=kb;EN-US;927695
RE: What does WSAEADDRNOTAVAIL mean?? - 2.Sep.2007 10:18:56 PM
tpduffo1
Tarek, thanks for your reply. Can you just clarify something though.
Are you suggesting I make the registry change on tghe ISA server or the protected server?
Another bit of info which is relevant which I should have mentioned earlier ;
Although server 192.168.x.242 cannot get web access ,
another server (server b) 192.168.y.30 ie in a different subnet but connected to the same NIC on the ISA server can browse websites without any problem.
Server B's Nic is configured as follows ;
192.168.y.30/24 with gateway 192.168.y.254
The gateway address 192.168.y.254 is also bound to the internal NIC on my ISA
Tim
