Whats the packagecode/GUID for MS_FWC.msi?
All Forums >> [ISA Server 2004 Firewall] >> Firewall Client >> Whats the packagecode/GUID for MS_FWC.msi? Page: [1]
Whats the packagecode/GUID for MS_FWC.msi? - 27.Oct.2005 12:32:00 PM
bdpconsulting
Does anyone know what the productcode or GUID (globally unique id) for the MS_FWC.msi is? I'm trying to install/uninstall via msiexec.exe but I need to specify the product code. Any idea where I can find it in the windows registry or a log file or something?
Derek
RE: Whats the packagecode/GUID for MS_FWC.msi? - 27.Oct.2005 9:04:00 PM
JeffVandervoort
The GUID will vary with the version, but after you install it, you'll find it in a subkey of HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall.
If you start a REGEDIT Find from that key searching on "Microsoft Firewall Client" with "Data" selected in the "Look at" group, the GUID will be the same as the key name in which you find the entry. (You'll also find the Uninstall String there, which is the MSIEXEC command line you'd need to issue.)
This script will also get you there:
List All Installed Software
(in reply to bdpconsulting)
RE: Whats the packagecode/GUID for MS_FWC.msi? - 28.Oct.2005 11:06:00 AM
bdpconsulting
Fantastic! Thanks for the help
