Why do a DMZ's addresses have to be public?
Why do a DMZ's addresses have to be public? - 30.Jun.2003 7:30:00 AM
AbqBill
Suppose you have a hardware firewall (e.g. Linksys), and it's internal interface has a non-routable IP address (e.g. 192.168.15.1). This router is performing NAT. Then you have an ISA Server behind it that has an external interface of 192.168.15.2, gateway 192.168.15.1. Subnet mask is 27 bits, so that network segment has 28 unused addresses.
The ISA Server has a bogus loopback adapter which is the only address in the LAT, and a third interface connected to the (actual) internal network. IP routing is enabled, but packet filtering is disabled. The idea here is to use ISA Server for outbound access control only, but we don't need ISA Server's NAT, so we fool it into thinking there's a DMZ, but of course the "DMZ" is actually the internal network.
According to repeated posts, the DMZ can't use non-routable addresses. Why not, if an upstream device is performing the NAT?
RE: Why do a DMZ's addresses have to be public? - 1.Jul.2003 4:14:00 PM
AbqBill
Why not? Suppose the upstream router only accepts traffic from the external interface of the ISA Server. A client can't just point their default gateway to the router and get out of the network; they have to use the ISA Server.
What I am getting at here is that there are some very good reasons that ISA Server should let the administrator control the NATting.
RE: Why do a DMZ's addresses have to be public? - 1.Jul.2003 6:59:00 PM
md3v
ISA is designed to be the perimeter firewall and a single point of entry/exit. The addition of the LinkSys device reduces ISA's status to a 'cache server' as ISA no longer has 100% control over the I/O on your external connection.
RE: Why do a DMZ's addresses have to be public? - 2.Jul.2003 6:50:00 PM
AbqBill
quote: Christopher wrote: ISA is designed to be the perimeter firewall and a single point of entry/exit. The addition of the LinkSys device reduces ISA's status to a 'cache server' as ISA no longer has 100% control over the I/O on your external connection.
Not if you configure the external firewall to only accept Internet-bound traffic from the "external" interface of the ISA Server. Not possible with a Linksys, but easy with a more capable product.
quote: tshinder wrote: So, true DMZ segments in ISA must have public addresses.
If both of ISA's interfaces use private addresses, if the external interface's subnet is not in the LAT, and the internal interface of the upstream firewall also has a private address in that subnet, then that subnet is a DMZ using private addresses. The external box could provide the appropriate "publishing" to make the DMZ appear on the public network, and appropriate packet filtering settings could make the DMZ servers available to clients behind the ISA Server.
It seems to me that this would be a very secure configuration...
RE: Why do a DMZ's addresses have to be public? - 2.Jul.2003 8:50:00 PM
Status: online
Hi Bill,
Excellent point! If you have another firewall in front of the ISA firewall, and the DMZ between the ISA and non-ISA firewall is private address, then you can use private addresses on the 3rd NIC of the internal ISA Server firewall.
Good one!
Thanks! Tom
RE: Why do a DMZ's addresses have to be public? - 2.Jul.2003 10:03:00 PM
AbqBill
That's not quite what I'm saying, but I didn't shift gears from the first post. I will start a new thread.
Bill
