WinXP and ISA FWC hang on next day reboot
All Forums >> [ISA Server 2000 Firewall] >> Firewall Client >> WinXP and ISA FWC hang on next day reboot Page: [1]
WinXP and ISA FWC hang on next day reboot - 8.Sep.2004 6:11:00 AM
I have a network with Win2000 SP4 domain and ISA 2000 Server SP2 in Indegrated Mode. The clients are WinXP SP1. The clients obtain the IPs via DHCP.
After FWC installation on any WinXP computer he follow problem arises:
1) Just after FWC installation all work fine.
2) On next day reboot the WinXP computer is loading VERY long. It seems as "NO DNS available" scenario. If I disable FWC - the loading is fine again. If I enable the FWC AFTER loading - all work fine.
The question: what can I do to provide smooth WinXP loading?
PS: The Win2000 clients with FWC are working fine at the same network.
RE: WinXP and ISA FWC hang on next day reboot - 9.Oct.2004 9:22:00 AM
nO IDEAS?
(in reply to Guest)
RE: WinXP and ISA FWC hang on next day reboot - 10.Oct.2004 2:22:00 PM
Hi aleks2,
make sure you run ISA SP2 and you re-install the Firewall client from the ISA share.
(in reply to Guest)
RE: WinXP and ISA FWC hang on next day reboot - 11.Oct.2004 12:38:00 PM
Surely
Have been done. Twice...
No result.
Addition:
If the ISA IP is used instead of ISA FQDN - all is fine. And at next day reboot is fine too...
(in reply to Guest)
RE: WinXP and ISA FWC hang on next day reboot - 11.Oct.2004 8:05:00 PM
Hi aleks2,
... then you should investigate your name resolution. I suggest you take a Sniffer or Ethereal trace of the client startup sequence to find out what is really happening on the wire.
(in reply to Guest)
