Wireless Radius Authentication
All Forums >> [ISA Server 2004 Firewall] >> Network Infrastructure >> Wireless Radius Authentication Page: [1]
Wireless Radius Authentication - 26.Jul.2005 6:50:00 AM
matthewhart
Is there anyway to allow PEAP/RADIUS traffic from a Netgear AP (WPA/RADIUS) through an ISA to an internal radius server (IAS)
It works without the ISA server on the same network but if you separate the clients and AP onto a separate network it can't authenticate
This is the basic layout of what I want
CLIENT LAPTOP >> AP >> ISA << RADIUS SERVER
I have access rules to allow all traffic from the
Local host to internal/wireless
Internal to local/wireless
Wireless to internal/local
Wireless and internal have a route relationship
Please help I can't find any thing on this.
Tom I have all the books if it is in there somewhere
RE: Wireless Radius Authentication - 26.Jul.2005 8:41:00 AM
ClintD
What does the Monitoring\Logging function show for the RADIUS Traffic? Use the Live logging function and add a "Client IP" and specify the APs address to help limit the results.
(in reply to matthewhart)
RE: Wireless Radius Authentication - 26.Jul.2005 9:57:00 AM
matthewhart
No traffic at all :-(
So I tried to install the IAS server on the ISA server itself, it works perfectly.
Do you think it is the wireless APs?
If you specify an address outside the subnet it sends no traffic, but when you specify the address of the ISA server it works perfectly (wireless interface i.e. same subnet)
RE: Wireless Radius Authentication - 26.Jul.2005 10:21:00 AM
ClintD
Who is the Default Gateway of the Netgear AP? It sounds like it doesn't know where to go if the RADIUS Server is off its subnet.
I wonder if you took a network trace from the ISA Server if you would see the AP ARPing for its Default Gateway or at least ARPing for some other device as it tries to contact the RADIUS Server.
RE: Wireless Radius Authentication - 26.Jul.2005 11:20:00 AM
matthewhart
The default gateway is set to the isa interface i thought the same thing. The AP log just has "timed out" so something isn't right but the ISA log is empty.
RE: Wireless Radius Authentication - 26.Jul.2005 11:32:00 AM
ClintD
Well, about the only other thing I can suggest is the Network Monitor trace of the AP attempting to communicate. You should at least see the ARP request from it.
RE: Wireless Radius Authentication - 26.Jul.2005 4:20:00 PM
matthewhart
ok, thanks for the suggestions they have been really helpful. At least it works on the ISA server that will get me started.
