Wireless Router
All Forums >> [ISA Server 2004 Firewall] >> Firewall Client >> Wireless Router Page: [1]
Wireless Router - 8.Jun.2007 11:13:45 AM
dpeters
Does anyone know if Microsoft changed something with the latest Firewall Client or a patch that breaks the ability to access the config page on a wireless router ( specifically a dlink ) if the IE proxy settings are turned on in the Firewall Client ? Proper internal DNS resolution no longer works correctly either. Everything used to work just fine but I just built a new machine with all the latest stuff and now it doesn't.
RE: Wireless Router - 8.Jun.2007 11:30:03 AM
you need to configure Internal Webpages to be Direct Access.
Tarek
(in reply to dpeters)
RE: Wireless Router - 8.Jun.2007 11:34:31 AM
dpeters
How do you do that ? And why didn't I need to do that before ? Plus doesn't "bypass proxy server for local addresses" address using 192.168.0.1 on a machine with an ip address of 192.168.0.x ?
(in reply to elmajdal)
RE: Wireless Router - 8.Jun.2007 11:44:55 AM
which service pack  you have on your ISA 2004 ?
RE: Wireless Router - 8.Jun.2007 2:48:37 PM
dpeters
The server has nothing to do with it. The problem is on the workstation.
RE: Wireless Router - 8.Jun.2007 5:18:24 PM
If you answered my last question, you would have the answer by now !!
Internal Web Servers, needed to be set as Direct Access in ISA Server, but i need to know which SP on you have installed on your ISA to point you to the correct Article.
RE: Wireless Router - 11.Jun.2007 8:28:34 AM
dpeters
SP2
RE: Wireless Router - 11.Jun.2007 1:00:46 PM
dpeters
If your talking about this
http://www.isaserver.org/tutorials/Configuring_Web_Proxy_Clients_for_Direct_Access.html
I still don't beleive that it has anything to do with my problem.
If I type in 192.168.0.1 into IE to access the web based config page on a wireless router connected directly to the workstation then I don't beleive ISA is even getting involved. The problem to me is with something in the network stack on the workstation. As I stated in my original post this used to work no problem up until recently so Microsoft changed SOMETHING.
RE: Wireless Router - 14.Jun.2007 2:20:55 PM
dpeters
No one has any idea ?
RE: Wireless Router - 14.Jun.2007 2:31:14 PM
Thats why i asked which SP u have on your ISA Server.
The article you pointed above applies to ISA Server with SP1, with SP2 , Direct access configuration changed, check this : https://blogs.technet.com/isablog/archive/2006/02/27/420653.aspx
Tarek
RE: Wireless Router - 14.Jun.2007 2:32:52 PM
interested in more readings, then check this : http://support.microsoft.com/default.aspx?scid=kb;en-us;920715
