XP Remote Desktop Behind ISA - Using Port 3391
All Forums >> [ISA Server 2000 Firewall] >> General >> XP Remote Desktop Behind ISA - Using Port 3391 Page: [1]
XP Remote Desktop Behind ISA - Using Port 3391 - 14.May2002 8:28:00 PM
tpry
I setup an XP Pro LAN client with remote desktop enabled - listening on port 3391. I then setup ISA server Protocol Definition - for Inbound 3391, Published Inbound 3391 - pointing to the IP address of the LAN Client (10.0.0.12, static). I can connect to the client on port 3391 from the ISA server itself, but from the outside (like from home) - I cannot get a connection. I do successfully get to the ISA server and then I can connect to the client by establishing another terminal session from there. I would like to avoid having to go through that extra step. Am I doing something wrong?
RE: XP Remote Desktop Behind ISA - Using Port 3391 - 14.May2002 8:33:00 PM
michaeljcarey
Why not use a Client VPN solution. Then your connection from home would be just like at work.
(in reply to tpry)
RE: XP Remote Desktop Behind ISA - Using Port 3391 - 14.May2002 9:03:00 PM
tpry
VPN is a good ides, but I need remote control for other reasons than simply connecting to data.
(in reply to tpry)
RE: XP Remote Desktop Behind ISA - Using Port 3391 - 14.May2002 9:32:00 PM
michaeljcarey
Actually once you establish the VPN you can then use XP to take remote control the way you would if you were in the office. I am not sure what limitations you have run into with VPN, but I have found very few. I use both PCanywhere, Terminal Services and XP to manage computers in the office remotely.
Am I missing something in your post?? [Roll Eyes]
(in reply to tpry)
RE: XP Remote Desktop Behind ISA - Using Port 3391 - 14.May2002 9:54:00 PM
bradwalsh
Have you thought about adding a static route on the ISA Server, pointing to that particular IP address?? I am not sure if that is the problem that you are running into....In RRAS, you can add routes to the routing table.....
Hope this helps
Brad
(in reply to tpry)
