YM Error when implementing authentication to Groups/Users
All Forums >> [ISA 2006 Firewall] >> Access Policies >> YM Error when implementing authentication to Groups/Users Page: [1]
YM Error when implementing authentication to Groups/Users - 7.Jan.2008 8:46:05 PM
iaculallad
I just had changed my ISA server configuration because I was testing the new GFI webmonitor 4 trial version. I removed some of the policies I created (which I know won't affect my users YM connection) a rule to authenticate existing OU groups when they try to connect to the net. The users inside the group can connect to the net but it seems that YM does not work anymore. What could be the probable cause for this case?
Thanks..
Ian Ace Culallad, CCNA
-There's Life in Every Star-
RE: YM Error when implementing authentication to Groups... - 8.Jan.2008 10:29:11 AM
pwindell
Set the YIM to not use a proxy,...assuming that it even has "proxy settings".
Install the Firewall Client software.
Probably in the past you had anonymous Rules that allowed the YIM to work.
Probably the YIM is not capable of [properly] authenticating to a proxy, as is common for many such applications.  The above steps will allow the YIM to work over an authenticated connection because it takes the burden off of the YIM and places it on the Firewall Client software.
Phillip Windell
www.wandtv.com
(in reply to iaculallad)
