Yahoo Messenger Help
All Forums >> [ISA Server 2000 Firewall] >> SecureNAT Client >> Yahoo Messenger Help Page: [1]
Yahoo Messenger Help - 31.Oct.2003 4:14:00 AM
arth020271@yahoo.com
Hi Techies,
I created the usual protocol rule for internet access and in the applies to tab it *Any Request*.
But when I set it in User and Groups (which i get it in the active directory) the yahoo messenger can't connect. We are in a secureNat client.
What is causing the problem?
Thanks a lot!
RE: Yahoo Messenger Help - 31.Oct.2003 11:07:00 PM
Benjamin
Hi Arth ...
It's better if you use ip range of computer for these protocols.
Saludos !
Benjamin
(in reply to arth020271@yahoo.com)
RE: Yahoo Messenger Help - 3.Nov.2003 10:21:00 AM
Hi thanks,
What IP ranges do you mean? I'm using DHCP on my client and default gateway is the ISA. Meaning my client changes the
On the LAT its define my local range of address.
Client Address Set?
Is that your settings? how is it?
Thanks a lot
RE: Yahoo Messenger Help - 3.Nov.2003 10:23:00 PM
sniper
Arth,
Yahoo messenger is not included in the list of protocols. You have to add a protcol definition for TCP 5050 to do this expan policy elements and right click on protocols and add the protocol definition. then the SNAT client will be able to use the new protcol.
Aslo it is impossible to authenticate users against protocol rules without the firewall client so make a cleint address set for the SNAT clients and bind access to the Client address set rather than users and groups
RE: Yahoo Messenger Help - 5.Nov.2003 11:05:00 AM
Hi Gregory,
Thanks for the info on the authentication! I made it.
With the Yahoo Messenger, the port is 5050 right?
What is the protocol type?
Direction?
Secondary connection? Yes or No
Do I have to configure the proxy settings on Yahoo Messenger?
arth
RE: Yahoo Messenger Help - 6.Nov.2003 6:16:00 AM
Hi!
Thanks to all of you! I have made it. It works even i put the users on the active directory.
Thanks for the info!
Arth
