Your thoughts on a Protocol issue.
All Forums >> [ISA Server 2000 Firewall] >> General >> Your thoughts on a Protocol issue. Page: [1]
Your thoughts on a Protocol issue. - 23.Oct.2002 5:51:00 PM
clynn
My company has been using ISA for quite some time now. Recently, our HR Dept upgraded their payroll to include a program that upload timesheet info. For the purposes of this post, I'll refer to the software as DPI. The technical folks at DPI Corp. say all we need is to aloow Bi-Directional TCP traffic on ports 80, 443, 5282, 6847, 6848, and 6849.
To do this I created a protocol called DPI to allow TCP traffic, starting with Inbound TCP on 5282, then adding the rest. I did not include ports 80 or 443 in that Protocol Definition.
Secondly, I made a protocol rule that allows this protocol during work hours, by all client on the internal network.
Is there something I am missing? Cuz I can't get the communication to work.
Oh yeah, when I bypass ISA with one of the clients, it works fine.
RE: Your thoughts on a Protocol issue. - 23.Oct.2002 10:40:00 PM
Hi clynn,
I suggest you do the following:
1) to get the most information out of the logfiles, I strongly recommend to enable the logging of all fields. In the MMC, go to the node Monitoring Configuration, then select Logs. In the details pane, right-click the applicable service and then click Properties. On the Fields tab, click Select All.
2) to understand what is logged, check out the ISA helpfile. There is a section called Firewall and Web Proxy log fields, a must read. Additional information can be found in the article Q284818.
3) create an open protocol rule (allow all IP traffic) and run a test.
4) analyse the web proxy and firewall log to confirm the protocol and ports used.
Also, can the technical folks at DPI Corp give you some more info:
- are this all primary connections are can some be considered secondary connections (like the data connection in the FTP protocol)?
- are all this connections outbound as seen by the clients?
(in reply to clynn)
