a little help with this error please
a little help with this error please - 11.Jan.2006 4:45:35 PM
ezpcc
Status: online
I could use a little help interpreting the following error please.. Alert Information: Description: ISA Server detected routes through adapter "Internal" that do not correlate with the network element to which this adapter belongs. The address ranges in conflict are: 172.17.0.0-172.17.16.255;172.17.18.0-172.17.255.254;.Fix the network element and/or the routing table to make these ranges consistent; they should be in both or in neither. If you recently created a remote site network, check if the event recurs. If it does not, you may safely ignore this message. ISA Server detected routes through adapter "External" that do not correlate with the network element to which this adapter belongs. The address ranges in conflict are: 172.17.0.0-172.17.16.255;172.17.18.0-172.17.255.255;. Fix the network element and/or the routing table to make these ranges consistent; they should be in both or in neither. If you recently created a remote site network, check if the event recurs. If it does not, you may safely ignore this message One other note, there is a third nic in this computer that was pointing to an internet address but it is not active... I am using 17.17.17.0 for my internal network... any hellp please ?? Thanks
RE: a little help with this error please - 11.Jan.2006 5:00:03 PM
ezpcc
Status: online
Hi Tom... thanks for your help... they are Ext Nic 64.19.182.163 255.255.255.248 Internal Nic 172.17.17.22 255.255.0.0 Guess I will need to change the subnet I bet... Thanks Aleks
RE: a little help with this error please - 12.Jan.2006 5:46:06 PM
ezpcc
Status: online
Ok... I guess I must go back to the drawing board.... and review my subnetting... I am not seeing it.. the 172 is a private address .. how is it in the same subnet ID?? I am very weak in the ip subnet department.. can you help to educate me please..? Thanks
RE: a little help with this error please - 12.Jan.2006 7:31:34 PM
Status: online
Hi EZ, Sorry about that, I made a mistake and misread the questions. Your subnetting looks OK. Disable the third NIC NIC if you're not using using it. Don't just unplug it, but disable it in the Network Connections folder. How have you defined your default Internal Network? Do you have the remote access VPN server enabled? If so, how are you assigning addresses to the VPN clients? Thanks! Thanks! Tom
RE: a little help with this error please - 19.Jan.2006 11:42:05 PM
ezpcc
Status: online
I am hoping you can help identifiy this error that I am now having since you were very instramental in helping me solve the last one... I am still having the authenciation problem between the ISA server and my AD domain. Trying to setup a granular VPN polciy - while adding an AD domain group or user I get the following error: Windows cannot process the object with the name "Domain Admins" because of the following error: The Remote Procedure call failed and id not execute Thanks Aleks
RE: a little help with this error please - 20.Jan.2006 1:27:23 AM
ClintD
Sounds like you have installed Windows 2003 SP1 (on the ISA Server or the DCs) and didn't install the required ISA 2004 SP1. This is the typical cause for the RPC call failed error.
