admin ISA2004 with ISA2006 mmc
All Forums >> [ISA Server 2004 Firewall] >> Management >> admin ISA2004 with ISA2006 mmc Page: [1]
admin ISA2004 with ISA2006 mmc - 4.Mar.2010 11:19:45 AM
mahaddon
Hi
I have some ISA2006 and ISA2004 servers and usually RDP to the 2004 server to admin and I have installed ISA 2006 mmc on my pc to admin the 2006 array.
I wondered if I can admin a 2004 standard ISA server with the same mmc as I can't install the isa2004 mmc (won't install as a newer version is already installed).  I have enabled mmc support on the ISA2004 system policy and added my pc to that and have created an ISA rule allowing my pc to connect.
When I try to connect from my pc mmc I get a server is not operational error and no errors in the ISA log presumable because my 2006 mmc wants to connect to a css and the 2004 standard edition doesn't have one????
RE: admin ISA2004 with ISA2006 mmc - 5.Mar.2010 4:16:51 AM
mahaddon
UPDATE
I've uninstalled my ISA2006 mmc and have installed the ISA2004 mmc and I got the same problems so it's obviously not a problem with incompatible versions.  Must be my ISA2004 rule  :(
(in reply to mahaddon)
RE: admin ISA2004 with ISA2006 mmc - 6.Mar.2010 8:49:00 AM
paulo.oliveira
AFAIK, you canīt even use ISA 2006 SE mmc to connect to ISA 2006 EE and vice-versa.
So, I believe it will not work with different versions either.
Paulo Oliveira.
RE: admin ISA2004 with ISA2006 mmc - 6.Mar.2010 5:06:45 PM
You have this option now with TMG EMS.
Where you can control EE & SE.
check Richards article : TMG Enterprise Arrays Explained
or my article : Managing Forefront TMG 2010 Remotely From a 32 bit Client
Windows Expert - IT Pro MVP
