auto discovery for 2 different networks in a single domain
auto discovery for 2 different networks in a single domain - 14.Feb.2008 10:49:53 AM
canibeyaz
Hi there, I have ISA 2004 sp3 with 3 NICs. One of the networks represent internal network (10.206.1.0 /24) , the other the external and 3rd one is for remote sites which are accessible through a router connected to ISA 2004. Everything works perfect except for one thing. I use wpad for auto discovery and i use dns name (http://myisaserversfqdn/wpad.dat) It works fine for the internal network. I want to do the same thing for remote network. i know that i cant use the fqdn of the isa server as its ip address is not reachable through remote networks interface. how can i do that ? any articles you guys could give me link to ?
< Message edited by canibeyaz -- 14.Feb.2008 10:53:27 AM >
RE: auto discovery for 2 different networks in a single... - 14.Feb.2008 11:46:32 AM
Rotorblade
Hi, Router connected to ISA? Will need a little more information. Can you diagram network and ISA interface(s) details? If the internal network and ISA server is not reachable from the remote network, then you need to fix internal routing! HTH RB
RE: auto discovery for 2 different networks in a single... - 14.Feb.2008 2:43:12 PM
canibeyaz
i guess that wasnt clear enough sorry. let me give detailed info. My internal network id is 10.206.1.0 /24 the interface of ISA is 10.206.1.109. FQDN is nwt-kavfw01.nwt.com.tr..The other interface is connected to the internet and has a public ip. The last interface connects to all remote networks (over 20 different subnets. ) . Ip address of the ISA interface is 172.16.44.1/30 and the interface of the router is 172.16.44.2/30 . The users in remote subnets uses 172.16.44.1 as their proxy settings and connects to the internet. i want to automatically publish proxy information for remote subnets like i do for internal network. btw, routing works fine. but as you know the remote networks are behind the interface of 172.16.44.1 so they cant use the internal interface of isa (10.206.1.109)..so i need to publish proxy info for 2 different networks.
< Message edited by canibeyaz -- 14.Feb.2008 2:56:12 PM >
RE: auto discovery for 2 different networks in a single... - 14.Feb.2008 2:58:19 PM
Hi canibeyaz, check out Multi-Networking WPAD Support in ISA 2004. As far as I know it applies to ISA 2006 too. HTH, Stefaan
RE: auto discovery for 2 different networks in a single... - 14.Feb.2008 3:08:00 PM
canibeyaz
thanks alot. thats what i had been desperately looking for. will give it a try and let you know.
RE: auto discovery for 2 different networks in a single... - 14.Feb.2008 3:35:19 PM
Rotorblade
To add... If you haven't done so, with the 20 subnets, you will need to create persistent static route mappings for each subnet that is reachable from the ISA remote network interface. This needs to be done on the ISA server. Also make sure that you have properly defined the Remote network object IP ranges in ISA for that network and its subnets. This should only include all the subnets reachable from that NIC. http://www.isaserver.org/tutorials/Configuring-Domain-Members-Back-to-Back-ISA-Firewall-DMZ-Part3.html HTH RB
RE: auto discovery for 2 different networks in a single... - 14.Feb.2008 5:27:12 PM
canibeyaz
i have done exactly the same things you mentioned. and as i said i dont have any problem with ISA configuration. all i wanna do is publish auto discovery for the remote subnets in addition to the internal network
RE: auto discovery for 2 different networks in a single... - 15.Feb.2008 3:39:12 PM
Rotorblade
Good, it should work them. Regards, RB
