blocking IP addresses
All Forums >> [ISA Server 2000 Firewall] >> Firewall Client >> blocking IP addresses Page: [1]
blocking IP addresses - 31.Dec.2001 8:31:00 AM
spittingfire
Hi All,
Just a quick question - Can the firewall block specific IP addresses? If yes how do I do it?
RE: blocking IP addresses - 31.Dec.2001 2:24:00 PM
of course ISA could do that ;-)
Can you be more specific what has to be blocked: from some IP's (client sets) are to some IP's (destination sets).
For more info goto http://www.isaserver.org/pages/learning%20zone.htm and buy Tom's book (highly recommended).
Hope this helps...
(in reply to spittingfire)
RE: blocking IP addresses - 31.Dec.2001 3:55:00 PM
spittingfire
Let's say for instance I want to block a specific user that has a static IP address from an ISP from viewing my website - how would I stop that IP address or can I?
RE: blocking IP addresses - 2.Jan.2002 1:12:00 PM
Hi Spittingfire,
is this an academic question ? ;-)
I really don't see what you want to achieve with denying access to your website for only one ip-address out of the whole Internet.
To answer your question: I've no docs are ISA at hand at the moment, but are you publishing the webserver? In that case you can restrict the client address set in the Client type properties (I think). If you are using a treehomed DMZ scenario, then you'll have to restrict access in your packet filters.
Hope this helps...
[This message has been edited by spouseele (edited 02 January 2002).]
RE: blocking IP addresses - 2.Jan.2002 7:43:00 PM
spittingfire
To be quite honest I don't want to block an IP address from accessing my website - What I really wanted to know is if there is a way to block a specific IP address that has port scanned your machine and drop those packets. I remember seeing somewhere that this can be done but don't remember where I saw it. All I want to know is how do I do that?
RE: blocking IP addresses - 3.Jan.2002 12:18:00 AM
OK, now I understand... ;-)
I think you are referring to the following article: http://www.isaserver.org/ubb/Forum2/HTML/002837.html.
The concept is to create a blocking packet filter.
Hope this helps,
RE: blocking IP addresses - 3.Jan.2002 12:33:00 AM
spittingfire
I tried the link but it is not working.
RE: blocking IP addresses - 3.Jan.2002 12:39:00 AM
PS: without trailing dot!
RE: blocking IP addresses - 3.Jan.2002 12:45:00 AM
spittingfire
got the link to work - thanks
Sorry for bothering you with all the questions - all I need to do is basically copy and paste the info and create a .vbs file. I guess I'll have to delete the ">" sign. Is there anything else I need to edit within the script to make it work?
RE: blocking IP addresses - 3.Jan.2002 12:58:00 AM
Hi Spittingfire,
I'll have to pass... I'm not a programmer or a VB scripter, but a network engineer. However, I understand what the functionality of the script is ;-)
As Tom suggested, "I suppose you can explore the SDK and maybe figure out how this works".
Of course, you can always create manualy the packet filter todo the job. But then the process is *not* automated.
Greetings,
RE: blocking IP addresses - 3.Jan.2002 1:41:00 AM
spittingfire
Thanks for all of your help. I'll take a look at all the information..
Once again thanks
