blocking p2p applications
blocking p2p applications - 21.Sep.2002 3:33:00 PM
Admin 786
my network performance is going down day by day as my remote clients have installed p2p applications like kazza ,morpheus ,winmx etc etc .. i know the ports my clients use to connect to it wat is the best way to block it ? wat would be appropiate ..
thanks
RE: blocking p2p applications - 22.Sep.2002 6:42:00 PM
Hi Gillani,
You should be able to block it by closing off TCP 1214.
HTH, Tom
RE: blocking p2p applications - 27.Sep.2002 5:47:00 PM
dejavu
HTH, Tom
RE: blocking p2p applications - 30.Sep.2002 8:16:00 PM
Hi dejavu,
Create a Protocol Rule that Denies access to TCP port 1214.
HTH, Tom
RE: blocking p2p applications - 22.Oct.2002 7:56:00 PM
Hey guys,
Another thing you can do it block the kaaza application using the Firewall client and mspclnt.ini entries.
HTH, Tom
RE: blocking p2p applications - 26.Jun.2008 6:09:05 AM
dwaynee77
BLOCKED 1214 TCP Outbound 12853 1745 18232 27507 34650 3531 3756-3761 3802 3885-3886 411-413 4115-4116 4661-4665 51958 6345-6348 6850 6881-6889 8227 6346 UDP Send 4129 UDp Send/Receive Dwaynee and Manutur @Jakarta, Indonesia. Please inform for difficulty or suggestion
