double ISP link & publishing ressources
All Forums >> [ISA Server 2004 Firewall] >> Network Infrastructure >> double ISP link & publishing ressources Page: [1]
double ISP link & publishing ressources - 19.Oct.2007 4:41:33 AM
Peter66
Hello Everybody,
Here's a descriptive of my actual setup:
ISA 2004 SP3, 4 NICs (1 LAN, 2 DMZ, 3 ISP-A, 4 ISP-B)
LAN & DMZ are private IP ranges.
ISP-A link = 1 public IP address (/30 subnet)
ISP-B link = 12 public IP addresses (/28 subnet)
a default gateway is set on each external NIC
traffic on ISP-a works ok :)
I've bound the IPs from /28 network on the NIC4 (ISP-B), i also added
Original setup was through the wizard 3legs setup as ISP-B has been added later. I've never used ISA in a 4 legs (2 external) config.
problems:
1- I don't see anything from NIC4 (ISP-B) for setting any NAT or any rules. I'd like to "map" some external IP addresses from the bunch I have on NIC4 (ISP-B) to several services: publish DNS, WWW, SFTP and few other things.
2- I'd like to eventually load balance outgoing http traffic from users, but it's a nice to have.
Questions:
1 - Is my network basic Setup correct ?
2 - How to see and use the available IPs from NIC4 (ISP-B) in my rules ?
3 -  Do I need to reconfigure the full ISA ?
Any advice would be great.
thanks in advance
Regards
Peter
RE: double ISP link & publishing ressources - 19.Oct.2007 9:00:22 AM
ISA Server Does not support multiple gateways ( ISPs )
(in reply to Peter66)
