eMule on machine running ISA 2004?
All Forums >> [ISA Server 2004 Misc.] >> Gaming >> eMule on machine running ISA 2004? Page: [1]
eMule on machine running ISA 2004? - 25.Jul.2005 3:28:00 AM
Hi, I have server for a home network, running ISA 2004.
Before installing ISA, emule was working fine.
Not it has lowid.
What settings/rules should I create to make it run again?
D.
< Message edited by Barbara Matysik Magro -- 18.Jul.2007 3:30:59 AM >
RE: eMule on machine running ISA 2004? - 25.Jul.2005 10:18:00 AM
Number51
by default, eMule uses TCP port 4662 and UDP port 4672. So your setup should look like this:
New Server Publishing Rule
Traffic:
TCP Port 4662 Inbound
UDP port 4672 Receive
External
To:
IP of pc running eMule
(in reply to Guest)
RE: eMule on machine running ISA 2004? - 25.Jul.2005 12:03:00 PM
Should I use the Externla IP of the server or internal IP of the server on the LAN?
My external is changinging - DHCP.
D.
(in reply to Guest)
RE: eMule on machine running ISA 2004? - 25.Jul.2005 1:01:00 PM
I created new protocol;
Port #: 4672
Protocol Type: UDP
Direction: Send
Port #: 4662
Protocol Type: TCP
Direction: Outbound
Secondary connections: 4672, UDP, Receive Send
4662, TCP, Inbound
4671, TCP, Inbound
Everything works now.
FROM "EXTERNAL" to "LOCAL HOST"
(in reply to Guest)
RE: eMule on machine running ISA 2004? - 27.Jul.2005 3:02:00 AM
emule web interface doesn't work, what should I do?
(in reply to Guest)
RE: eMule on machine running ISA 2004? - 27.Jul.2005 8:53:00 AM
Number51
New server publishing rule for the port the web-interface runs on. Default is 4711. From "External" to the pc serving the application.
(in reply to Guest)
RE: eMule on machine running ISA 2004? - 27.Jul.2005 10:35:00 AM
My serveris the one that has the application, so should I point to it?
In that case it has two IPs - external and intarnal. External changes every now and then because of DHCP. So what should I do?
(in reply to Guest)
