firewall clients login directly
All Forums >> [ISA 2006 Firewall] >> Firewall Client >> firewall clients login directly Page: [1]
firewall clients login directly - 27.Jun.2008 3:18:14 AM
IQ TECHNOLOGY
Hi all ISA genius
Can any one tell me how can control the firewall clients login to the server  ??
Because for now any one install the software can login to the network without asking for its user and password in the active directory !!
Please can you give the right procedure to configure the firewall clients with user name and password or any documents for this point ??
Regards
IQ TECHNOLOGY
RE: firewall clients login directly - 27.Jun.2008 4:50:09 AM
IanC
The firewall client forwards the credentials transparently.  Have a look at this...
http://technet.microsoft.com/en-gb/library/bb794762.aspx
Ian
Ian Currie
http://www.curriecomputing.com
(in reply to IQ TECHNOLOGY)
RE: firewall clients login directly - 27.Jun.2008 5:11:02 AM
IQ TECHNOLOGY
Thanks for your replay
I can understand the login procedure happened in the background
But the problem  is even when I remove the user from the AD or disable it , it still can log to the server  !!
Its mean there is no login procedure and the firewall client connected directly to the server
I hope some explain
Best Regards
IQ TECHNOLOGY
(in reply to IanC)
RE: firewall clients login directly - 27.Jun.2008 5:45:08 AM
IanC
You will need to specify the users who are permitted to access the remote server in the access rule.  By default, this is set to All Users which means no authentication is required.
Ian
Ian Currie
RE: firewall clients login directly - 27.Jun.2008 6:05:59 AM
IQ TECHNOLOGY
and what u  will say IanC  , if I told you that I remove the term All User and and put  instad the Authenticated Clients
Regards
< Message edited by IQ TECHNOLOGY -- 27.Jun.2008 6:08:37 AM >
IQ TECHNOLOGY
(in reply to IanC)
RE: firewall clients login directly - 27.Jun.2008 7:56:44 AM
IanC
That's fine.
Ian
Ian Currie
RE: firewall clients login directly - 28.Jun.2008 3:06:18 AM
IQ TECHNOLOGY
Thanks Ian C
but its not fine !!
i need some one tell me how can solve this problem
Im asking the right way to control the firewall clients login
Im asking for , if I delete a user from the AD , it cannot login even it is a firewall calient
please some body help
Best Regards
IQ TECHNOLOGY
(in reply to IanC)
RE: firewall clients login directly - 29.Jun.2008 4:54:42 AM
log to what ?
Internet ? file sharing ?
You disabled or even deleted the user from AD, then how come you are still able to logon to the machine using the deleted/disabled credentials ? cached credentials ok for some time but later on these cached credentials will get expired and you will no longer be able to logon on the machine with the deleted/disabled credentials !!!
I didnt understand what you are discussing here, can you please tell me more details about your issue .
Tarek
