anyone can tell me if i run my FTP in DOS, i cann't get it work with ftp but it works with ftp -a, i know that i have to delete the external IP address on the ISA server, but i cannot do that, since both NIC IP address are internal. So what other solution that i can use IE browser for FTP??? how to use FTP -a in IE???
any one can help?? the reason why i can't delete the external IP is, my current IP setting like this External IP:192.168.0.2 External Gateway: 192.168.0.1(which is symantec firewall, hardware) Internal IP: 192.168.68.1 Now my case is both IP are in ISA LAT, i cannot delete 192.168.0.1 this IP, because if i delete it, client computer cannot go Internet, and cannot recognise the DNS. What other solution to fix that FTP problem???
hi stefaan, what will be wrong of my isa setting, i can get it done in another ISA that i setting, i exclude the external LAT in another ISA, it works. but for this ISA, once i delete the external LAT, the ISA server itself and the client computers cannot go to Internet, and the DNS also not work. What i might be mistaken in the isa setting??
hi, i have delete the external address for LAT in ISA, everything work fine in the LAN, clinet computers can access Internet and FTP, no problem in outgoing traffic. BUT from outside cannot access the LAN, i cannot use terminal service outside, cannot access the local web site. what will be the problem??? any body can help????
in order to give external users access to internal resources, you need to web or server publish those resources. For more info, check out the ISA Help file and http://www.isaserver.org/pages/learning_zone.asp .
