how i speed My Http Browising?
All Forums >> [ISA Server 2004 Firewall] >> HTTP Filtering >> how i speed My Http Browising? Page: [1]
how i speed My Http Browising? - 18.Feb.2007 5:19:46 AM
leroi
i have Littel Problem speed of browising very slow when i put isa srv
but in Norml Router good
i ask if there r some tools to test browising and accelerate it  ?
i have cach installed !!!!!
isa 2004
RE: how i speed My Http Browising? - 18.Feb.2007 7:28:46 AM
Hi leroi,
Tarek
(in reply to leroi)
RE: how i speed My Http Browising? - 19.Feb.2007 2:48:46 AM
lchuzel
be  sure IP routing is enable (with that ISA use kernel mode)
the option is in general - ip preferences - ip routing  - Enable ip routing
2- You can encrease speed by adding this values :
HKLM\system\currentcontrolset\services\tcpip\parameters
ForwardBufferMemory (DWORD KEY) = 80000 (décimale)
MaxForwardBufferMemory (DWORD KEY) = 80000 (décimale)
3- If you have two NIC and two processors on your server you can activate infinity filter (you find it in windows 2003 Ressource Kit infinity)on network card  and dedicate one card for input an the other for output
program intfiltr.exe in  c:\Program Files\Windows Resource Kits\Tools
before using it don't forget to register it with this reg key
REGEDIT4
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\InterruptAffinityFilter]
"Type"=dword:00000001
"Start"=dword:00000000
"ErrorControl"=dword:00000001
"ImagePath"=hex(2):53,79,73,74,65,6d,33,32,5c,44,52,49,56,45,52,53,5c,69,6e,74,\
66,69,6c,74,72,2e,73,79,73,00
"DisplayName"="Interrupt Affinity Filter"
Hope help you
L chuzel
(in reply to leroi)
