how to block ip block
All Forums >> [ISA Server 2004 General ] >> General >> how to block ip block Page: [1]
how to block ip block - 23.Jul.2008 5:41:22 AM
its4u_waqar
hi all!
any one tell me plz how can i block the internet 2 ip of my network by ISA SERVER 2004?
RE: how to block ip block - 23.Jul.2008 7:15:09 PM
Create a Computer Set.
  1. In the ISA Server Management console tree, click Firewall Policy.
  2. On the Toolbox tab, click Network Objects.
  3. On the toolbar beneath Network Objects, click New, and then click Computer Set.
  4. In Name, a name for the computer set.
  5. Click Add, and select Computer, Address Range, or Subnet, depending on the object that you are adding to the computer set. Provide the required information for the object that you selected. Repeat this step as necessary until the computer set contains all of the required computers, address ranges, and subnets.
  6. Click OK to close the dialog box.
Then Creat a Rule :
Deny > All Outbound Protocols > From Computer Set > To External > All Users
Make sure to put this deny rule above allow rule.
(in reply to its4u_waqar)
RE: how to block ip block - 24.Jul.2008 1:59:42 AM
its4u_waqar
elmajdal thanks for share with me its working thanks allot i m your fan
u take care always
Best Regards
Waqar
(in reply to elmajdal)
RE: how to block ip block - 24.Jul.2008 4:52:12 AM
RE: how to block ip block - 29.Jul.2008 2:32:37 AM
its4u_waqar
sir this rule is gr8 working but there i m facing an other problem. the problem is that when i apply this rule its block a browser internet but file is still downloading means if this computer already downloading some thing its won't stop only browsing will be stop i want to block all internet access from that computer so plz any good way... ?
Waqar
