how to combine two ADSL line for load balancing
All Forums >> [ISA 2006 Firewall] >> General >> how to combine two ADSL line for load balancing Page: [1]
how to combine two ADSL line for load balancing - 22.Oct.2008 5:06:13 AM
ancientbagan
Hi all,
First of all, Let me introduce myself first.
I'm from myanmar (burma). at my work (internet cafe),
I've two ADSL internet connection (Donwstream : 512Kbps, Upstream : 256Kbps)
Now, i'm using two isa server for each line seperately. i want to combine these line for outbound and inbound load balancing.
Is this possible ?
if yes, which type of hardware or isa configuration do i need ?
my compaq server have four broadcom NIC with teaming and failover function. can i use this function to combine ?
all helps and advices will be appreciated
thanks in advance
RE: how to combine two ADSL line for load balancing - 22.Oct.2008 7:23:15 AM
SteveMoffat
You'll need a twin WAN Router. Xincon & Netgear have a few models.
Steve
www.isaserver.bm
(in reply to ancientbagan)
RE: how to combine two ADSL line for load balancing - 23.Oct.2008 12:15:01 AM
ancientbagan
thanks SteveMoffat
Can i use network teaming function integrated with broadcom NIC ?
ORIGINAL: SteveMoffat
(in reply to SteveMoffat)
RE: how to combine two ADSL line for load balancing - 23.Oct.2008 8:37:03 AM
SteveMoffat
Yes you can, but that won't help with 2 adsl routers. Teaming turns 2 nics into 1 nic basically.
You would still need a routing device.
Steve
www.isaserver.bm
RE: how to combine two ADSL line for load balancing - 23.Oct.2008 9:09:14 AM
paulo.oliveira
Hi Steve,
If I not mistaken, Team NICs doesn´t work very well with ISA...
I´ve seen too many people complain about this before... or this issue only happens with ISA EE+NLB?
Paulo Oliveira.
RE: how to combine two ADSL line for load balancing - 24.Oct.2008 4:17:13 AM
ancientbagan
Dear Steve and paulo.oliveira
We all in myanmar can get only 512Kbps ADSL line becasue of our junta's ISP. so, i bought 2 line and tried to combine to get double bandwidth with NIC Teaming function and ISA Server 2006.
but, it doesn't work well.
Pls help me
ORIGINAL: paulo.oliveira
Hi Steve,
Paulo Oliveira.
(in reply to paulo.oliveira)
RE: how to combine two ADSL line for load balancing - 24.Oct.2008 7:30:23 AM
SteveMoffat
Hi
There is no way around it. You need a hardware solution.
Steve
www.isaserver.bm
RE: how to combine two ADSL line for load balancing - 24.Oct.2008 9:17:42 AM
ancientbagan
Hi Steve
So, you mean, i need dual wan router. yes ?
if i have two seperated ISA Server, can i combine these two line without dual wan router ?
my lines are the followings.
1st line
ip address : 172.24.xx.xxx
subnet mask : 255.255.254.0
gateway : 172.24.44.1
2nd line
Hi
RE: how to combine two ADSL line for load balancing - 24.Oct.2008 11:40:10 AM
SteveMoffat
You can do it with 2 isa's, but they would be separate firewalls. You would have to split your clients between them.
Rainconnect used to do it, but it it no longer avaiolable.
A twin wan router is your nest bet.
Steve
www.isaserver.bm
RE: how to combine two ADSL line for load balancing - 24.Oct.2008 12:59:37 PM
adimcev
Yep, as Steve said.
Google for outbound load balancing, inbound load balancing, for example, you will get many results for various products, vendors and the way they accomplish the load balancing, what features they offer...
Say: http://www.xincom.com/twinwan.php
Also you may find some reviews/tests for various products.
Looking at your IP addresses and DGWs, it looks like you use two Internet connections from the same ISP. That does not sound very good in respect with the failover idea.
Adrian
Blog: http://www.carbonwind.net/blog
Get Our ISA 2006 Book!: http://tinyurl.com/2gpoo8
RE: how to combine two ADSL line for load balancing - 27.Oct.2008 1:42:45 AM
ancientbagan
Dear paulo.oliveira
Can i use 2 ISA Server EE + NLB to combine these two adsl lines for Load Balancing.
Hi Steve,
Paulo Oliveira.
RE: how to combine two ADSL line for load balancing - 28.Oct.2008 1:46:42 PM
paulo.oliveira
I don´t think you can do this, the best option will be use another hardware in front of ISA Server.
Paulo Oliveira.
